Old 2nd February 2017, 09:34 AM
Good point Scott, but I am thinking a visual check of the mounts would suffice.
Old 2nd February 2017, 01:23 PM
[quote=ScottD3;123670]Its still a rubber mount, ignoring the electronic side of it.
Rubber breaks down, like all bushes and needs replacing and these being hydro they can leak.
The error might be a premature warning and they don't need replacing at all but they will need replacing at some point.
Surly putting a resistor in is like turning the stereo up when your front arms start to knock?[/QUo:TE]
If its a subframe drop to do them better do the subframe mounts whilst your there .......then rear subframe .....then every suspension arm then anti roll bar .....
Old 2nd February 2017, 01:36 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
If you're going that far, might as well drop the unside, clean and reseal. haha
I've removed a set from a breaker and I don't recall it needing to drop the subframe.
As the mounting faces was flatish, all you have to do was remove the bolts, support the engine and lift a little, slide the mounts out and replace.
relatively easy job.
I had the sub frame drops, front or rears.
Trying to align them so they are correct is a bitch!!
[center]
06 3.0TDI Quattro:
Options:
Old 2nd February 2017, 03:12 PM
Well ......if they are not to bad to do, go for it
Old 2nd February 2017, 06:08 PM
Joe2.0E Joe2.0E is offline
From memory, the labour was only 1.5 hrs when i had one done under warranty, the price of the part is the issue for me.
It's your money but as i said previously, I wouldnt bother as i dont believe you'll notice whether it's been replaced or not.
Maybe ask to test drive a similar members car that doesnt have the fault code & see for yourself if it's worthwhile.
Old 12th October 2020, 10:54 AM
ulfilias ulfilias is offline
That's MY kinda fix
I just got an error code on my 2005 D3
I'm a bit curious how, if audi has put resistors in....or if the mounts on mine are real they've lasted THAT long!!!
I've had the car for some years and 40k+ miles
Current :
Previous :
Also :
Old 12th October 2020, 12:07 PM
homer simpson's Avatar
I've had this error on my car since I had it and was advised on here that is the mounts themselves are ok then ignore it. Apparently a common fault code to be thrown up on a D3
Old 12th October 2020, 12:55 PM
It's ODD that it has just recently come up, and a couple of times. I run LPG and that often adds codes so i frequently clear those (typically o2 exhaust).
Current :
Previous :
Also :
