Old 17th February 2017, 09:01 AM
Question Help with a Battery Manager audit? ...
Guys; following an ongoing forum discussion with Ross Tech regarding A8 D3 Battery Manager [BEM] ECUs, I wondered if any of you with 'early' A8s [2003 and 2004 cars] could help with survey re. Firmware levels? [Yes, I know there aren't many out there]
'Early' A8s had a Version 1 ECU where the battery cable connected underneath the ECU rather than into the middle of it. However, the good thing for these early BEM ECUs is that you can read the label easily [the V2 ECUs, with the cable going to the middle tend to make it difficult to read the ECU label].
I'm trying to correlate actual HW/SW/FW numbers to label numbers, so to assist, you really need a VCDS scan of the ECU as well as to look at the label. All I'd like to know is the first three lines of the VCDS scan of the ECU 61 and the Part number / SW number / version numbers [two numbers to the right of part numbers] off the label.
Note: I'm doing this because some ECUs seem to have a mismatch between the versions on the label and the versions 'found' by a VCDS scan.
Thanks - Julian
Old 17th February 2017, 09:49 AM
Here's mine. I think it's been replaced in the past as it's old software and the WSC is all zeros...
Code:
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181     HW: 4E0 915 181
   Component: ENERGIEMANAGER  H02 0160
   Revision: 00000000    Serial number: 00000000013302
   Shop #: WSC 00000 000 00000
   VCID: 5DB18073842382AAE5-8008
Matt
Old 17th February 2017, 11:42 AM
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000018428
Shop #: WSC 02313 785 00200
VCID: 204F0F15F34C1D3E5E-8074
Old 17th February 2017, 11:45 AM
Thanks Marcin; but what does the ECU sticker say?
Regards - Julian
Old 17th February 2017, 11:43 AM
Thanks Matt; but what does the ECU sticker say?
Regards - Julian
BTW, the original ECUs seem to be 'good'. Yours may have been in the car since new - have a look at the date on the label. Some of the early A8 ECUs tended to have zeros where you don't see them later. My [very early] Telephone ECU has zeros in various places.
Old 17th February 2017, 11:46 AM
Regards - Julian
Ah sorry, I'll look later... I'm at work.
Matt
Old 17th February 2017, 12:00 PM
And I note that you're following the long running thread at Ross Tech. Looks like your BEM level of 0160 indicates no history logs are stored in it!
Julian
Old 17th February 2017, 05:36 PM
Julian,
Here is mine, SWMBO is out in the car so I'll try and look at it tomorrow.
Revision: 00000000 Serial number: 00000000010676
VCID: 5DB1B54184D4E3C924D-8008
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 301008803E
Coding: 303030393135313035414B56413033303130303838303345
Shop #: WSC 73430 210 01865
No fault code found.
