Old 12th April 2017, 06:51 AM
chrisc201 chrisc201 is offline
Thanks for suggestion, got a scan lined up for Friday morning so I'll see where that leads me... I did have a look on the pdf's about removing glove box and got a little intimidated!
Fingers crossed something simple / cheap!!
Intermediate cut outs on the MMI is most likely to be a loose connection behind the glovebox somewhere on the optical loop, probably best to take out the glovebox and then check the visible connectors to see that they are all seated properly and not loose
