Go Back   A8 Parts Forum > A8 D4 > D4 - Everything Else
D4 - Everything Else Holding forum for all D4 banter until membership grows and we'll expand out
Old 5th July 2021, 07:15 AM
Anyone with ODIS access can do the formal full coding to Audi back office - my local indy in West Sussex has the kit (needed to do it for retrofit of a RVC kit to my Golf GTI)
Can't help with the other queries, I'm afraid, although been thinking I've had my S5 so long I should fit a towbar for bikes......
Old 5th July 2021, 07:31 AM
Many moons ago I fitted a swivelling towbar to my D4. My lasting memory was the degree of contortion required through the process, both for the bolts mentioned and of course, getting the wiring into the fusebox which was far from comfortable.
Coding wise, I used VCDS, logically going through each module and adding the towing byte, assisted by the Kufatec instructions. It worked a charm until it went in to the dealer next when they reset everything and lit the dash like a Christmas tree! As I was on good terms with them, they fixed this by adding the factory PR code on their system and resetting again.....
As for a pre-facelift on a post=facelift car - I can't say for sure, but I do have a facelift ECU in the garage somewhere, although no-longer have a D4
Old 5th July 2021, 10:05 PM
I believe that A8 Ian no longer looks at the forum.
I could be wrong.
