D2 - Everything else Anything that doesnt fit elsewhere |
Here's the result of the scan, clean modules removed:
VCDS-Lite Version: Release 1.2 Wednesday, 07 June 2017, 11:10:02:65169 ------------------------------------------------------------------------------- Address 01: Engine Labels: 4D0-907-560-AVP.LBL Controller: 4D0 907 559 AA Component: 4.2L V8/5V G 0002 Coding: 10753 Shop #: WSC 02629 VCID: 6DADB4263489 WAUZZZ4D63N001043 AUZ7Z0A2019960 7 Faults Found: 17831 - Secondary Air Injection System; Bank 1: Insufficient Flow P1423 - 35-10 - - - Intermittent 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-00 - - 16688 - Cylinder 4: Misfire Detected P0304 - 35-00 - - 16686 - Cylinder 2: Misfire Detected P0302 - 35-00 - - 16685 - Cylinder 1: Misfire Detected P0301 - 35-00 - - 16687 - Cylinder 3: Misfire Detected P0303 - 35-00 - - 16690 - Cylinder 6: Misfire Detected P0306 - 35-00 - - Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8D0-907-389.LBL Controller: 4D0 907 389 E Component: ABS/ESP allrad D57 Coding: 08397 Shop #: WSC 02313 VCID: 31156856E831 1 Fault Found: 01119 - Gear Recognition Signal 35-10 - - - Intermittent ------------------------------------------------------------------------------- ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.LBL Controller: 8L0 862 257 P Component: CV-Pump, Alarm, RC D17 Coding: 16235 Shop #: WSC 02314 VCID: 42F7379A5D97 5 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00955 - Key 1 09-00 - Adaptation Limit Surpassed 01134 - Alarm Horn (H12) 76-10 - Terminal 30 missing - Intermittent ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: None Controller: 4D0 951 177 B Component: Innenraumueberw. D06 Coding: 00001 Shop #: WSC 00000 VCID: 28238532DBEB 1 Fault Found: 01350 - Alarm via Theft Warning System; Rear 35-00 - - ------------------------------------------------------------------------------- End -------------------------------------------------------------------------------------------------- I cleared the engine codes and ran it for a few seconds while stationary, none returned, but....
It's plausible that the 01119 error is suggesting a failing F125 switch but the main obvious problem is a very rattly catalyst!
![]() Quote:
![]() Also recoded barzya8's central locking module to match mine. He had been on 15179 which didn't actually make much sense but was partly working. Mine (and his now) is on 14315 which does what I want and appears (after testing) to do what he wants as well. Just to clarify my code of 14315, which was arrived at after a fair bit of experimentation long ago..... It's basically everything ON except: 4 (drivers door only with key blade), 512 (single flash confirm on radio lock), 2048 (US window logic, operation disabled with doors open) and 16384 (drivers door only with remote).
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 7th June 2017 at 12:37 PM. |
Big thanks to HPSauce for the VCDS lesson. Have already shared with David down at DS Autowerks and initial response on the misfires is a faulty air flow meter. Will update once he gets back to me with a clearer view.
2002 S8 Aqua Pearl, entirely original apart from FE 20" OEM wheels and Milltek exhaust. |
Glad to be able to help.
![]() Remember you will need to do another scan to confirm the engine problems; I don't think I cleared the codes properly before you went for a "spin" after the first scan, but I think I did after the second look but only ran the engine for a few seconds then? You really should invest in VCDS, assuming you have a suitable laptop, as it puts you in control with so much more information. It really is essential on these cars.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 7th June 2017 at 03:54 PM. |
Car was perfect on the way back. Behaved much better than on the way there. Yes I'm going to look into VCDS but given I'm about invest in new MAF sensor, 4x new tyres and 2x refurbished cats I'm going to leave it a week or two....
Fair enough, but make sure the MAF is tested before assuming that's a problem. With VCDS (and other tools) you can check/log the readings.
Also, if your F125 switch is playing up you can get very odd behaviour as the ECU's don't know what gear you're in.
![]() Quote:
OK will do. Just out of interest how easy is it to replace the MAF? Job for the home mechanic or novice?
Changing MAF is a doddle, I've swapped mine several times while testing problems.
Bit of big air trunking and related stuff to remove, handful (or less) of screws, that's about it. And a wiring plug. I have a spare one you could swap in on a temporary basis to see if it changes anything.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 8th June 2017 at 07:36 AM. |
