Old 7th August 2017, 07:24 AM
VCDS will tell you all you need to know in regards to the status of the door handle, you can also do test on button and see if it responds in measuring blocks
Old 7th August 2017, 12:10 PM
daandaman daandaman is offline
Mine is intermittent. Specifically when wet. It can actually blow bubbles or squirt bits of water.
I think a fix could be to inject very thin silicon caulking after drying it out thoroughly with maybe a syringe. It would set so you don't get oil on your finger every time you press the button but also will stay flexible enough to be able to click the switch. However i would really really like to see someone taking a door lever apart to see what switch is used and how the button cover looks like from the inside to see if a method of sealing can be applied in a more technical manner.
Old 7th August 2017, 06:37 PM
Same here
Old 8th August 2017, 02:38 AM
roberto's Avatar
roberto roberto is offline
someone must have a duff handle if they have changed one
come on all you guys have a look around
please dont tell me you have thrown them away
also...
i noticed the button on my drivers door (which has failed) has sunk down a touch
while the other 3 stand flush or even proud a tad they click nicely too
so maybe the failed buttons collapse inside
Old 8th August 2017, 06:24 AM
also...
I did
They are not user serviceable, trust me, if it could be done I would have done it .
Old 8th August 2017, 11:31 AM
Not everybody is a regular user, could you please upload a picture or two?
Old 8th August 2017, 05:06 PM
No, they are in the bin.
Old 8th August 2017, 08:24 PM
roberto's Avatar
go get them out im going to do this
Old 8th August 2017, 08:46 PM
Ok let me explain clearly.
Said handles were removed, inspected for possible repair, conlusion was they not repairable, they were then transferred to the bin, which was collected by Waveney council.
Once collected I can only guess that they ended up in the landfill which they use.
I don't know the location of said landfill but I'm sure if you contact them directly they will be glad to tell you where it is.
http://www.eastsuffolk.gov.uk/waste/...-and-disposal/
Old 8th August 2017, 10:32 PM
I've had a word with East Suffolk disposal services. They are very polite but a bit dim. It took a while for them to get their heads round my simple request. Anyway after what sounded suspiciously like ill suppressed laughter they told me that they were happy for me to look for the said door handles, but first I need to obtain a doctors note testifying that I represent no risk to the public in general and their workers in particular. I'll let you know how that goes.
Anyone got a metal detector I can borrow?
