Old 19th August 2017, 06:51 PM
All the Tech infoi including Service manual for ALL the separate elements of the car are on this forum at the "Tech Dump" sticky under "D2 - Common Problems" thread heading . No cost
(See "Service Manual - Air Conditioner - Sect 7.12 p 166)
Old 20th August 2017, 04:08 PM
mannyo mannyo is offline
The whole manual is available here on this forum, look in the Tech Dump at the top of the topic list, it has everything you ever wanted to know about the D2.
http://forum.a8parts.co.uk/showthread.php?t=9345
Manny
Past
Old 20th August 2017, 04:19 PM
A8essex A8essex is offline
After very generous help from Conquistador, the errors that come up are as follows (which seems like lots of issues !!). Can anyone translate it into what needs fixing? thx
Address 08: Auto HVAC Labels: 4D0-820-043-MYX.lbl
Part No: 4D0 820 043 M
Component: A8-Klimavollautomat D12
Coding: 00081
Shop #: WSC 02313
VCID: 264580C3C265DF2ECEF-2566
7 Faults Found:
00713 - Centre Left Vent Positioning Motor (V110)
41-00 - Blocked or No Voltage
00657 - Positioning Motor for Central Vents (V102)
00712 - Right Footwell Flap Positioning Motor (V109)
41-10 - Blocked or No Voltage - Intermittent
00715 - Rear Footwell Vent Positioning Motor (V112)
01274 - Air Flow Flap Positioning Motor (V71)
00733 - Potentiometer in Positioning Motor for Rear Footwell Vent (G141)
30-10 - Open or Short to Plus - Intermittent
01592 - Air Quality Sensor (G238)
57-10 - Electric Circuit Failure - Intermittent
