Old 30th September 2017, 11:44 AM
Originally Posted by karlcossy View Post
is that the abs module? could not do anything with that coding wise unless I'm doing it wrong
Not ABS but the radar module. It's currently coded for a trailer hitch. Your scan, now deleted, didn't show this. I can't help too much without the full scan.
Matt
Old 30th September 2017, 12:02 PM
karlcossy karlcossy is offline
ill try another scan laptop wouldn't let me save it this morning so got a bit stressed
Old 30th September 2017, 12:18 PM
Saturday,30,September,2017,13:16:26:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
VIN: WAUZZZ4E65N002074 License Plate: T22KRL
Mileage: 187180km-116308mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 1D 1E 25
28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 66 67 72 76
77
VIN: WAUZZZ4E65N002074 Mileage: 187180km-116308miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
66-Seat, Rear -- Status: Cannot be reached 1100
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 07C-910-018-BHT1.lbl
Part No SW: 4E0 910 018 HW: 4E0 906 018
Component: 6.0L W12/4V A ª0110
Revision: -------- Serial number: AUX3Z0D4341645
Coding: 0011773
Shop #: WSC 00353 210 62620
VCID: 5C52777F5F24D7F2F9A6A1-8008
No fault code found.
Readiness: 0000 1000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 J HW: 09E 927 156 A
Component: AG6 09E 6,0L4V RdW 0060
Revision: 00000001 Serial number: 0037043
Coding: 0000001
VCID: 2ABEE1A745F07942BB9A87-807E
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 C HW: 4E0 614 517 BD
Component: ESP 5.7 allrad H44 0330
Coding: 0007637
Shop #: WSC 12345 000 00000
VCID: 23A00C8322DAA80AF85CD2-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D4341645
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: 585A6B6F2B1C3BD2DD4E9D-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
3 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 30
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.29
Time: 10:32:18
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 72
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.29
Time: 10:32:18
00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 30
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.29
Time: 10:32:18
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H01 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063968
Shop #: WSC 00000 785 00200
VCID: 24A20F9F27D4AF328156D9-8070
2 Faults Found:
02095 - Component Protection Active
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 186272 km
Time Indication: 0
Date: 2017.07.03
Time: 01:14:26
01964 - Control Module for Seat & Steering Column Memory (J136)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 0 km
Time Indication: 0
Date: 2005.01.01
Time: 00:00:00
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300FF047536342
Coding: 0000002
VCID: 3A9ED1E7B550C9C2CB7AD7-806E
Subsystem 1 - Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Subsystem 2 - Serial number: 318EG047506302
Subsystem 3 - Serial number: 7405.05.040000000000010069ÿ
Subsystem 4 - Serial number: 010069ÿ
2 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 31
Mileage: 187177 km
Time Indication: 0
Date: 2017.09.30
Time: 11:02:00
01319 - Control Module for Distance Control (J428)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 4
Reset counter: 32
Mileage: 187181 km
Time Indication: 0
Date: 2017.09.30
Time: 11:11:07
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 A HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 016 0300
Revision: 00000025 Serial number: 00000000046407
Coding: 0389369
VCID: 1BD034631AAA90CA302C7A-804E
4 Faults Found:
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.27
Time: 20:01:56
Freeze Frame:
Temperature: 20.0°C
01856 - Temperature Sensor for Heated Seat; Front Right (G345)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.27
Time: 20:01:56
Freeze Frame:
Temperature: 20.0°C
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 13
Reset counter: 32
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.28
Time: 17:44:22
Freeze Frame:
Voltage: 12.70 V
01854 - Heated Seat; Front Right (Z46)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 69
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.29
Time: 10:31:19
Freeze Frame:
Temperature: 14.0°C
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 J HW: 4E2 955 113 B
Component: ILM Fahrer H12 0190
Coding: 0133121
Shop #: WSC 02313 785 00200
VCID: 2F88F0B37E121C6A6CE45E-807A
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0040
Coding: 00141886
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000000 Serial number: AUZ5ZBC1015724
Shop #: WSC 00000 000 00000
VCID: 1CD2377F1FA497F2392661-8048
1 Fault Found:
02084 - Component Protection
Freeze Frame:
Fault Priority: 4
Fault Frequency: 254
Reset counter: 119
Mileage: 275443 km
Time Indication: 0
Date: 2017.03.02
Time: 17:53:11
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276W7101465
Coding: 0000001
Shop #: WSC 02152 785 00200
Address 11: Engine II Labels: 07C-910-018-BHT2.lbl
Coding: 0011773
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0041218
VCID: 25A4129B2CEE563A9648CC-8070
2 Faults Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10110100
Fault Priority: 5
Fault Frequency: 5
Reset counter: 71
Mileage: 187176 km
Time Indication: 0
Date: 2017.09.30
Time: 00:44:00
Freeze Frame:
Temperature: 20.0°C
Voltage: 12.67 V
Bin. Bits: 00100000
01044 - Control Module Incorrectly Coded
000 - - - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 5
Fault Frequency: 6
Reset counter: 32
Mileage: 187176 km
Time Indication: 0
Date: 2017.09.30
Time: 11:01:00
Freeze Frame:
Temperature: 18.0°C
Voltage: 11.14 V
Bin. Bits: 00100000
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0430707
VCID: 63204C83625AE80AB8DC12-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112151
VCID: 6524529B6C6E963A56C80C-8030
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 931 E HW: 4E0 920 931 E
Component: KOMBIINSTR. VDO H70 0400
Revision: D01 Serial number: AUDID3E5000168
Coding: 0032443
Shop #: WSC 00999 444 64523
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 B
Component: Gateway H07 0070
Revision: 07 Serial number: 15004048120502
Coding: FEFFFFFC3B7D04
Shop #: WSC 00720 210 86425
1 Fault Found:
00462 - Control Module for Seat Memory; Rear (J522)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 42
Reset counter: 32
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.27
Time: 19:35:57
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 A HW: 4E2 905 218 B
Component: FPI_1 H01 0010
Revision: 01000101 Serial number: 11042005084300
VCID: 1FA800730EB28CEADC040E-804A
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 0
Reset counter: 30
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.27
Time: 20:03:40
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 0
Reset counter: 70
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.29
Time: 10:31:32
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H20 0850
Revision: 00000000
Coding: 010000
VCID: 2BB0E4A34A0AA04A408C8A-807E
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0412672
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 30
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.29
Time: 10:32:18
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 32
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.29
Time: 10:32:18
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 30
Mileage: 187120 km
Time Indication: 0
Date: 2017.09.29
Time: 10:32:18
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 B
Component: KLIMA-STG. FOND 015 0220
Revision: 00000018 Serial number: 00000000026849
Coding: 0000000
VCID: 612C468B7846FA1AAAF078-8034
2 Faults Found:
02291 - Control Module for Seat Vent; Rear; Driver Side (J674)
02292 - Control Module for Seat Vent; Rear Passenger Side (J675)
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 00353 210 89229
VCID: 28BA1BAF5BFC4B52ADAEED-807C
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H01 0010
Coding: 4063982
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 32
Mileage: 186272 km
Time Indication: 0
Date: 2017.07.04
Time: 00:30:41
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H43 1060
Revision: 00000000 Serial number: 353FY047523897
VCID: 3B90D4E3BA6AF0CAD06CDA-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H02 0090
Serial number: 00000413900087
Coding: 0036070
VCID: 1DD43A7B04BE9EFACE1814-8048
2 Faults Found:
00211 - Control Circuit for Rear Illumination Lights
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 28
Mileage: 187104 km
Time Indication: 0
Date: 2017.09.23
Time: 00:55:00
02138 - Control Circuit for Front Right Interior Lights
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 0
Fault Frequency: 3
Reset counter: 71
Mileage: 187124 km
Time Indication: 0
Date: 2017.09.28
Time: 17:44:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRMH01 0060
Coding: 0032751
VCID: 20AA038F33CCB312E57E35-8074
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040406080130
Coding: 0004857
VCID: 27B8189356E2442AA4B4E6-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial number: 00000000003257
Coding: 0000017
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000042258
Coding: 0010101
VCID: 1ED63D7709B885E2D7121B-804A
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRMH01 0060
Coding: 0032751
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000631
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000003
VCID: 622E49877D40E102B3EA6F-8036
1 Fault Found:
02235 - Stationary Cornering Lamp (Left) (M51)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 70
Mileage: 187128 km
Time Indication: 0
Date: 2017.09.27
Time: 19:20:35
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 B
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 304FS047595508
Coding: 0000001
VCID: 318CF6CB68260A9A7AD048-8064
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 D HW: 4E0 919 148
Component: R0078 TVhybridTuner 0440
Revision: R0H06000 Serial number: 76300800403102
Coding: 0000303
Shop #: WSC 31414 790 00001
4 Faults Found:
00863 - Antenna 1 for TV (R55)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 21
Reset counter: 32
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.27
Time: 19:48:33
00864 - Antenna 2 for TV (R56)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 20
Reset counter: 32
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.27
Time: 19:48:31
00865 - Antenna 3 for TV (R57)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 19
Reset counter: 32
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.27
Time: 19:48:31
00866 - Antenna 4 for TV (R58)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 21
Reset counter: 32
Mileage: 187127 km
Time Indication: 0
Date: 2017.09.27
Time: 19:48:31
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H11 0510
Revision: 00000000 Serial number: 00000000002193
Subsystem 1 - Part No: 000 915 105 DL
Component: von VA0 350117H281
Coding: 303030393135313035444C56413033353031313748323831
Shop #: WSC 12345 128 00289
5 Faults Found:
02273 - Quiescent Current Stage 2
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Time Indication: 0
Date: 2017.09.30
Time: 01:39:22
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 187177 km
Time Indication: 0
Date: 2017.09.30
Time: 01:58:26
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 187177 km
Time Indication: 0
Date: 2017.09.30
Time: 01:58:36
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 187177 km
Time Indication: 0
Date: 2017.09.30
Time: 01:58:46
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 71
Mileage: 187177 km
Time Indication: 0
Date: 2017.09.30
Time: 07:56:31
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM002 0060
Coding: 0032751
3 Faults Found:
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 221
Mileage: 187104 km
Time Indication: 0
Date: 2017.09.08
Time: 10:47:56
02130 - Interior Door Lighting
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 72
Mileage: 187104 km
Time Indication: 0
Date: 2017.09.17
Time: 18:43:08
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 68
Mileage: 187104 km
Time Indication: 0
Date: 2017.09.20
Time: 10:43:30
Address 66: Seat, Rear
Cannot be reached
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000403240081
Shop #: WSC 12336 024 394758
VCID: 3686C5D781482DA22F2203-8062
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM002 0060
Coding: 0032751
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 221
Mileage: 187104 km
Time Indication: 0
Date: 2017.09.08
Time: 10:47:56
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 68
Mileage: 187104 km
Time Indication: 0
Date: 2017.09.20
Time: 10:43:30
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08730413301313
Coding: 0101108
VCID: 21AC068B38C6BA1AEA7038-8074
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 K HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005025638
Coding: 0010900
Shop #: WSC 02335 758 00200
End-------------------------(Elapsed Time: 04:06)--------------------------
Old 30th September 2017, 08:25 PM
Some rather strange faults there. All over the place date and time wise.
I would do as Sean (steamship) suggested, clear all the faults and start again, but this time time clear manually one controller at a time. If any of the controllers fail to clear all it's faults, go back to that controler and try again after you have cleared all the others. I have found on occasions that the controllers have reported the faults found by other units, causing some confusion. Simply put; knickers in a knot syndrome.
Try and not give up, it can be very frustrating. Remember before computers came along all these problems would not have been "found" and logged and you would have been happily driving around in ignorance. Now you are on a steep learning path.
Good luck with it.
Old 3rd October 2017, 06:39 PM
just an update for all and thankyou for all your help I was getting a little stressed to say the least but after checking everything and going over each module deleting fault codes it jumped in to life I have not touched the setting screws on the radar its self and so far all seems good
had to modify front grill as finding one with acc seems rare lol
