Old 1st March 2018, 01:22 PM
I replaced mine 5 years ago (also ASB). None were faulty, but I replaced them anyway as I enjoy tinkering. I used NGK Y-609AS but to be honest they were a tiny bit shorter at the tip (~3mm) but they do another one now that is not... Y-1002AS
I didn't have any problems removing them with a hot engine that had rested for about 20 minutes. I also soaked them in plus-gas spray a week before and again after stopping the engine before doing the job.
There was some aluminium from the head sort of smeared on the threads and they feel like they are gripping the aluminium too tight when unscrewing. You need 1/4" drive deep socket and wobble extension and a low-torque torque-wrench such as used on bicycles. It's really important to be square on to the plug when unscrewing to stop them snapping.
Some early A8's had ceramic plugs which are very fragile. Only in 2003-2004 IIRC. these had a different colour band on the collar (you will have to google it) and the ECU also gives them a different voltage so would need recoding if changing to metal plugs. Also double-check the part number corroborates on a webfew sites, as I found some trying to sell wrong ones.
Don't be too scared, but do stop if your gut instinct says so and leave a seized plug in.
Old 1st March 2018, 09:06 PM
neeldub neeldub is offline
How many components under the engine cover do you need to set aside in order to get a good and clear access to the glow plugs?
I ordered these Bosch glow plugs from Euro Car Parts
https://www.eurocarparts.com/ecp/c/A...281f785&000164
What do you think?
Previously:
2010 Audi A8 4E Quattro Sport TDI Oyster Grey
Currently:
2015 Audi A8 4H Sport Executive Quattro in Monsoon Grey
Old 2nd March 2018, 07:17 PM
Around page 108 - not much IIRC, just the power connectors.
The right (driver's) side are easier, do those first. I thing the front left was the trickiest but was years ago.
Attachment 18079
Everything seems to say install dry, but you could use a little engine oil as a cutting oil if they were hard to get out ans screw them in a turn anb back a quarter and repeat like with a tap or die..
Old 7th March 2018, 11:23 PM
H-M3 H-M3 is offline
Can anyone advise the correct part number for the 4.2tdi 2006 (glowplug) cheers
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 9th March 2018, 05:27 PM
Hey 059 963 319M superceeded by newer part number 059 963 319S
Previously:
Currently:
Old 10th March 2018, 12:59 AM
Cheers Neel
Tags
asb, glow plugs
