D3 - Everything Else Anything that doesnt fit elsewhere |
Thread Tools
Display Modes
Guys; having had long time battery charging issues, with supposedly 'good' battery and alternator, I'm now determined to try and get to the bottom of it.
I've had my 2005 A8 for 10 years now but VCDS only for about 2. Sadly, I've never tried to use VCDS to monitor what's going on until now. I'm focusing attention on the Battery Manager ECU's measurement blocks, as Group 1 - fields 1 and 2 - show the 'alternator output [requested]' and the 'battery voltage [measured]' in real time. I'm interested in the BEM values when the engine is idling after a start. I've looked at my numbers several times in the last few weeks and they consistently show Alternator 14.3V and Battery 13.7V I've directly asked one forum member for his numbers - Thanks Ray - but I'd be grateful if a few other forum members [4 or 5?] with VCDS could do a quick check of those ECU 61 Group1 fields when convenient and enter their values here for comparison. However, if you'd like to contribute to the thread and you haven't got VCDS, I'd still be interested in seing what your battery voltage is, engine on and idling, measured with a DVM. Thanks - Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! |
Julian,
My battery is two years old now
Mine are 14.30v and 13.20v and is stating 50% state of charge
Battery was installed december 2016, but this will be my third battery in 6 years. First one was killed by a faulty alternator, the second two I think is down to excessive starting drain due to leaking injectors (fuel collects in the piston bores)
2004 A8 3.0 TDI Sport Brilliant Black - now gone |
![]() Quote:
Those numbers are even stranger than I think mine are ![]() I know that the Battery Manager [BEM] is only 'requesting' 14.3V but I can't understand the voltage drop to 13.7V in my case [and 13.2V in yours]. Those numbers aren't really good enough to be charging the battery. Interestingly, Ray's was over 14V. The trouble is that although the BEM can directly measure the battery as it's 'right next door', it's not 'seeing' the Voltage level of the output from the alternator. So I guess some sort of test at the alternator is required. ![]() Hopefully we'll see some other results from other cars ... Julian
I dealt with a parasitic drain on my D2 for a long time before I eventually solved it.
I had a bung voltage regulator on the alternator. It 'tested fine' with an auto elec. It measured 13.7V running with lights on full beam and aircon on. Parasitic drain remained until I went with my gut and replaced the Voltage Regulator (and bearings and slip ring). So you just have to figure out now whether the D3 battery monitor is capable of picking up a failing voltage regulator?
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived ![]() Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) |
![]() Quote:
The attached diagram shows only one connection from the BEM to the alternator [in blue] and that's its 'voltage request line', I believe. As per my comment to SRG above; I guess it needs a voltage check for the alternator output to see if it's giving the 14.3 it's asked for. If it is, I think I might have 'voltage drop' but I've no idea how that battery current gets to and from the front of the car. ![]() Julian
Somebody on here, sorry can't remember who posted a photo of the big positive cable from the battery to the engine area which had a connection around the driver's footwell which looked a bit poor and had overheated due to contact resistance and high current and it needed fixing.. Maybe that is causing the voltage drop?
Sorry, I can't find the post now. Last edited by snapdragon; 14th May 2018 at 05:18 PM. |
That’ll be this one I assume
http://forum.a8parts.co.uk/showthread.php?t=13499
![]() Quote:
I have always suspected lhigher-than acceptable osses between the BEM/battery and alternator and vice-versa to starter. (Low charging voltage at battery when you would expect it to be high, and somewhat lazy starter) Attachment 18841 Attachment 18842 Last edited by snapdragon; 23rd April 2020 at 08:18 AM. |
