Old 7th December 2019, 08:55 AM
Default Weird start/non-start problem - help needed
I have a suspicion what this might be but don't know enough...…
Started the S8 this morning, no problem, even though it hasn't been used for a couple of weeks. Let it run while I checked the tyres - one has a very slow leak yet to be fixed.
Went out, stopped to post some Xmas cards, got back in the car and it wouldn't start. Lights on as normal but no action whatsoever from the starter.
Bit of a panic as I was on a mainish road and half-blocking the driveway next to the post box!
Somehow by moving the gearlever and operating the key it suddenly started so I went back home.
Turned off, removed key and tried to start - no starter action, not even a click.
Moved the gearstick to different positions and tried again, still didn't start.
Then I kept my foot on the brake AND the key turned to start and began moving the gear lever around and it fired up.
I think it was as I was moving from D to N that the starter kicked in. The engine actually started in a fraction of a second as it usually does.
So I'm guessing this is something to do with safety circuits (and switches?) ensuring you can only start the car in P or N.
But how to I check, confirm and rectify whatever is going on? Thanks in advance for any advice.
