Old 28th July 2020, 09:04 AM
Mossyboy1978 Mossyboy1978 is offline
Default New key
Morning all
One of my keys has gone through the wash and now doesn’t work. I’ve opened it up and spotted some rust around the batteries and some white misting on the circuit board. Might be time for a new key. Is this relatively simple or am I going to have to ask a dealer to do a new key for me at a cost of remortgaging my house?
Many thanks
Mossy
2002 S8 Aqua Pearl, entirely original apart from FE 20" OEM wheels and Milltek exhaust.
Old 28th July 2020, 09:22 AM
First thing to do is thoroughly and carefully clean up and dry the inside of the failed key and try with fresh batteries.
Secondly, there are regular mentions here of specialist(s) who can supply new keys for D2s, often in more "interesting" designs. Neil has used someone regularly and I think even arranged for them to attend owners meets. A search might find some references.
Hopefully he'll spot this and give his recommendations, as will others. But a dealer trip is not really needed and the technology might even be too old for them!
IIRC VCDS can cope with all the key matching/coding required for authentication, though specialists will have their own tools to do the job.
Old 28th July 2020, 09:57 AM
I think the immobilizer part should still be working as the chip is sealed and there are no batteries for it and you will only need remote fob part and remote can be paired to car by yourself as long as you have the second key. Remotes are about £100 from dealer, new aftermarket or used genuine Audi are around £15-20
Old 28th July 2020, 10:26 AM
Good point ainars, I'd forgotten that. Is it simple to identify the chip and move it to a new key? I've swapped batteries but never looked at the other bits inside.
I now recall doing similar things with my old Ford Focus which had the same generation technology and pairing remotes was really simple if the immobiliser was already valid. Though in that the immobiliser chip was very obvious, separate and easily moved to a new key. Ford used 2 different but compatible versions; earlier ones were in a sort of tiny glass phial which "could" break but later ones were solidly embedded in plastic.
Definitely worth trying to start the car with the damaged key though, you can probably unlock the door with the blade.
Alarm might go off but should stop once the car is started, or unlock with the working remote on a first test?
Old 28th July 2020, 10:42 AM
The D2 chip is the glass one and can't be moved to another key as it is epoxied in place. Coding a new key from scratch requires the immobiliser pin which is non-trivial to get. Audi just plug it in to the mothership and it happens automagically, but aftermarket tools are available to extract it. VCDS can't code it without the pin.
I can't remember the company name of Neil's locksmith either, but he did keys for a few of us at the 2018 meet.
Old 28th July 2020, 11:12 AM
Just use the old key with immo chip, it should still be working and starting car, I assume it's just remote not locking/unlocking doors and get a new remote: https://www.ebay.co.uk/itm/VW-AUDI-4...da28%7Ciid%3A1
Old 28th July 2020, 11:13 AM
Unless you already have it on scratch-off tag, which I actually do for my S8!
It looks like this (image courtesy of Ross-Tech):
So is the immobiliser chip in the key section, so you can just replace the remote locking part? Dead simple if it is.
Coding in a new remote is very simple, all described in the Ross-Tech wiki. Though there's a finite number (5 maybe?) so you can run out.
I think I did it when I got my current S8, erased all the remotes (requires VCDS) then just added the two I had.
Old 29th July 2020, 11:11 AM
I remember having issues with an A4 back in the late 90s... when they weren't epoxied in place. Had washed the car at the weekend and dropped my key on the wet tarmac drive. The key literally fell apart. I picked up the 'three' pieces, two plastic sides and button battery and put it back together again.
Monday morning came and wife drove car to her work using her key. She went into work and I set about driving to mine, except the car kept dying out after starting. Tried it about a dozen times and then phoned Audi, as the car had got this far. He suggested the key might be faulty and to try another one. Got wife's key and got to work. Called into Audi later on to check key and have it coded again, only to find that the transponder was missing from inside!
Tags
key
