D3 - Body and Exterior Bumpers, bonnets, glass, trims - Everything outside |
There are two separate pumps, so a failed pump is an option. Another option could be completely blocked nozzles, due to a build up of grime. If it's leaking pipework, chances are you'd see a puddle of water under the front bumper when you try washing the headlights.
![]() Quote:
Would a scan show anything?
Phantom Black 2008 A8 3.0 TDI SE ASB |
Highly unlikely, and in terms of physical access to the pumps to test them, that means removing the rear part of the driver side wheel arch, and you could try putting 12v across them.
Thanks for the help. I'm thinking the problem might be cracked pipework as there was a bit of a puddle under the nearside bumper I've since discovered. I'm struggling to find a diagram of the pipework routing so looks like I'll just have to get in there and have a proper look.
![]() Quote:
