Old 14th May 2025, 04:08 PM
Well done Steve. I "think" that's the only F125 problem that actually "kills" the car.
Everything else is variations of annoyance up to permanent "Limp mode" in the gearbox. But even then it's driveable.
Old 14th May 2025, 09:26 PM
sarg sarg is offline
She behaved herself tonight so hopefully the workaround will stick until I can get it sorted permanently
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 15th May 2025, 06:35 AM
2. Unscrewed the (aftermarket) access panel - apparently this one is not one of Sean's, but not OEM either, so not sure what Mark did here
FYI, Steve, Mark made the access panel has his was badly affected by water ingress
Old 15th May 2025, 07:40 AM
As Jim pointed out, Mark made his own replacement relay cover, and it was his inspiration that made me make a replacement for mine... and a few spares for others with the leftovers. Here's his original thread about it:
https://forum.a8parts.co.uk/showthread.php?t=11673
Old 15th May 2025, 08:09 AM
Thanks both for the info, I'd spoken with MJ about it previously, she was sure it was one of Sean's
That and Mark tackling Botang's hole has done the job, it is bone dry in there
Old 4th June 2025, 11:33 AM
donp38 donp38 is offline
I think the bypass is a more reliable fix..
