Old 27th November 2022, 04:37 PM
Let us know what happens when you get the jumper plugs inserted. That might allow the MMI and radio to work properly, assuming that one of the other modules is causing a problem. Once you get the MMI sorted, you should be able to change the date/time.
Old 4th December 2022, 01:57 PM
Garry1's Avatar
Garry1 Garry1 is offline
Got time with the car today
Connected the jumper and found it is the amplifier which is faulty
Managed to change date and time as you say
Any one repair the amplifier 4E0910223C
Will have a look inside incase it's a dry joint as it has switched on a few times and worked while driving
Audi A8 d3 4.2 petrol 2004
Blue
Old 4th December 2022, 06:53 PM
Hopefully it's just a dry solder joint.
I can only find one company online that repair Bose amps, but only from year '06 onwards. You could always email them to confirm, just in the off chance that they could do it: https://boserepairexperts.co.uk/
Old 4th December 2022, 08:25 PM
Garry1's Avatar
Thanks for your help steamship
I will let you know what I find when I open it tomorrow
Hope fully a dry joint or dead capacitor
One problem I do have is heavy steering
Very strange
Car does have adjustment on the column
But not working I did clear the error but it comes back instantly
Blue
Old 5th December 2022, 12:22 PM
Very strange
What's the error code you're getting for the steering?
Old 10th December 2022, 05:05 PM
Garry1's Avatar
Unsure what I have done
Changed the amplifier and it worked for a couple of mins then shut down
Sunday,04,December,2022,12:16:04:08597
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
Control Module Part Number: 4E0 910 468
Component and/or Version: Gateway H07 0070
Optical Bus Diagnostic : 3dB Attenuation
Controller Electrical Optical
19-CAN Gateway OK OK
07-Control Head(High/D3) OK OK
0E-Media Player 1 ERROR ERROR
1E-Media Player 2 OK OK
47-Sound System ERROR ERROR
56-Radio OK ERROR
57-TV Tuner OK OK
37-Navigation OK ERROR
0F-Digital Radio ERROR ERROR
Saturday,10,December,2022,11:24:47:08597
www.Ross-Tech.com
VIN: WAUZZZ4E84N015326 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 13 15 16 17 19 1E 1F 25 2E 34
36 37 38 3E 42 46 47 4E 4F 52 53 56 57 5E 61 62 65 72 76
VIN: WAUZZZ4E84N015326 Mileage: 116120km-72153miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
13-Auto Dist. Reg -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
1F-Sat. Tuner -- Status: Cannot be reached 1100
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: Cannot be reached 1100
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: OK 0000
3E-Media Player 4 -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4E-Ctrl Head RR -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
57-TV Tuner -- Status: Cannot be reached 1100
5E-Ctrl Head LR -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 Q HW: 4E0 907 560
Component: 4.2L V8/5V G 0030
Revision: 00000000 Serial number: AUX3Z0CN127976
Coding: 0011773
Shop #: WSC 00411 210 96661
VCID: 2F381B434B1F5523428-807A
VINID: 9D196AAAA1152047800450C21865F1B97A
2 Faults Found:
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V RdW 0110
Revision: 00000001 Serial number: 0025352
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 2412E46F12D9E67BAFA-8070
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 M
Component: ESP 5.7 allrad H44 0500
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 221EE27708CDE84BDD6-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131
Component: FBS AUDID3 H03 0130
Revision: 01303703 Serial number: AUX3Z0CN127976
Coding: 0264192
Shop #: WSC 02311 785 00200
VCID: 58EA809F1E11729BF32-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Shop #: WSC 00000 785 00200
VCID: 2310E77317D7E143D60-8076
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 016 0240
Revision: 00000022 Serial number: 00000000030648
Coding: 1069057
VCID: 5AEE9A97601D608BC56-800E
4 Faults Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 207
Mileage: 116124 km
Time Indication: 0
Date: 2022.12.10
Time: 11:19:47
Freeze Frame:
Temperature: 20.0°C
00819 - High Pressure Sensor (G65)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 195
Mileage: 115825 km
Time Indication: 0
Date: 2003.04.03
Time: 23:18:10
01857 - Air Outlet Sensor; Middle Left (G347)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 38
Reset counter: 246
Mileage: 115826 km
Time Indication: 0
Date: 2003.04.03
Time: 23:50:49
01858 - Air Outlet Sensor; Right Center (G348)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 20
Reset counter: 246
Mileage: 115826 km
Time Indication: 0
Date: 2003.04.03
Time: 23:50:58
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0000001
VCID: 2A0E0A5770FD300B956-807E
Subsystem 1 - Part No: 4E2 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02311
1 Fault Found:
02510 - Steering Column Adjustment
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 254
Reset counter: 78
Mileage: 22878 km
Time Indication: 0
Date: 2009.05.01
Time: 09:37:15
Address 0E: Media Player 1
Cannot be reached
Address 0F: Digital Radio
Cannot be reached
Address 13: Auto Dist. Reg
Cannot be reached
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
VCID: 6390A7735757A143960-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112141
VCID: 6594B96B5963DF73784-8030
Component: Lenkradmodul H03 0070
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 CX
Component: KOMBIINSTR. VDO H42 0070
Revision: D08 Serial number: AUDID3C6000184
Coding: 0016403
Shop #: WSC 00411 210 175099
VCID: 5CE29C8F6A299EBBD7A-8008
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0070
Revision: 07 Serial number: 1400303A0625E4
Coding: FEFE5BDDFBAD07
Shop #: WSC 00976 210 82602
9 Faults Found:
00384 - Optical Databus
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 98
Reset counter: 207
Mileage: 115825 km
Time Indication: 0
Date: 2003.04.03
Time: 23:30:10
02076 - Media Player Position 1 (R118)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 116010 km
Time Indication: 0
Date: 2003.04.10
Time: 12:27:01
02078 - Media Player Position 3 (R120)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 116010 km
Time Indication: 0
Date: 2003.04.10
Time: 12:27:01
02079 - Media Player Position 4 (R121)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 116010 km
Time Indication: 0
Date: 2003.04.10
Time: 12:27:01
02230 - Digital Radio (DAB) (R147)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 116010 km
Time Indication: 0
Date: 2003.04.10
Time: 12:27:01
02075 - Rear Right Information Display Control Head Control Module (J649)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 116010 km
Time Indication: 0
Date: 2003.04.10
Time: 12:27:01
02074 - Rear Left Information Display Control Head Control Module (J648)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 116010 km
Time Indication: 0
Date: 2003.04.10
Time: 12:27:01
02218 - Satellite Radio (R146)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 116010 km
Time Indication: 0
Date: 2003.04.10
Time: 12:27:01
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 238
Mileage: 116010 km
Time Indication: 0
Date: 2003.04.10
Time: 12:27:01
Address 1E: Media Player 2
Cannot be reached
Address 1F: Sat. Tuner
Cannot be reached
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0264192
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 2E: Media Player 3
Cannot be reached
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 2514F96B19E31F73B84-8070
1 Fault Found:
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 26
Reset counter: 246
Mileage: 115826 km
Time Indication: 0
Date: 2003.04.03
Time: 23:51:07
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H07 0060
Coding: 4063330
Address 37: Navigation
Cannot be reached
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0090
Serial number: 00000331300033
Coding: 0035840
VCID: 1D64D18B31B3D7B3E04-8048
Address 3E: Media Player 4
Cannot be reached
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 802
Component: Türsteuer.FS BRM005 0110
Coding: 0028450
VCID: 5EE696877C358CABB9E-800A
1 Fault Found:
02111 - Motor for Window Regulator
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 199
Mileage: 116032 km
Time Indication: 0
Date: 2022.12.06
Time: 07:34:42
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040311180041
Coding: 0000217
VCID: 2708F36363EF0D638A8-8072
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
2 Faults Found:
00892 - Switch for Trunk Closing Cylinder (F248)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 64
Reset counter: 238
Mileage: 115730 km
Time Indication: 0
Date: 2003.04.01
Time: 04:35:15
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Reset counter: 206
Mileage: 68437 km
Time Indication: 0
Date: 2013.03.03
Time: 14:23:29
Address 47: Sound System
Cannot be reached
Address 4E: Ctrl Head RR
Cannot be reached
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000027974
Coding: 0010101
VCID: 1E66D6873CB5CCABF9E-804A
1 Fault Found:
01797 - Power Steering Hydraulic Pressure Valve (N119/N315)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 69
Reset counter: 247
Mileage: 115664 km
Time Indication: 0
Date: 2003.03.28
Time: 01:10:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 801
Component: Türsteuer.BF BRM005 0110
Coding: 0028450
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 HW: 4E0 907 801
Component: EPB A01H019 H01 0190
Coding: 0000531
Shop #: WSC 00022 210 75084
1 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01110000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 130
Time Indication: 0
Freeze Frame:
Voltage: 12.01 V
Count: 61
Address 56: Radio
Cannot be reached
Address 57: TV Tuner
Cannot be reached
Address 5E: Ctrl Head LR
Cannot be reached
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 A HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0230
Revision: 00000000 Serial number: 00000005308435
Shop #: WSC 12345 128 00289
Subsystem 1 - Part No: 000 915 105 SD
Component: von TU3 1310310534
Coding: 303030393135313035534454553331333130333130353334
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM005 0110
Coding: 0028450
VCID: 5DE4918B713397B3A04-8008
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0252127
VCID: 5F98AB837B3F85A3B28-800A
2 Faults Found:
01477 - System Switched Off
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 58
Reset counter: 236
Mileage: 115595 km
Time Indication: 0
Date: 2003.03.21
Time: 03:57:08
Freeze Frame:
Speed: 0.0 km/h
Temperature: 11.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 186
Mileage: 115601 km
Time Indication: 0
Date: 2003.03.26
Time: 21:46:00
Freeze Frame:
Speed: 9.0 km/h
Temperature: 7.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM005 0110
Coding: 0028450
2 Faults Found:
00470 - Company Comfort Databus in Single Wire
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 235
Mileage: 115824 km
Time Indication: 0
Date: 2003.04.03
Time: 22:39:08
01482 - Motors for Central Locking
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 2
Reset counter: 242
Mileage: 116048 km
Time Indication: 0
Date: 2022.12.07
Time: 17:01:62
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 00000332500058
Coding: 0001008
VCID: 211CED7B0DCBF353C4C-8074
1 Fault Found:
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 187
Mileage: 115664 km
Time Indication: 0
Date: 2003.03.28
Time: 01:10:19
End----(Elapsed Time: 01:53, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Blue
Old 11th December 2022, 09:44 AM
Two things.
1. The amplifier has component protection, so that needs removed before it will operate properly. I believe the symptoms you mentioned is what happens with CP active. This is of course assuming that when you say you 'changed' the amplifier, you put in another one.
2. When clearing the error codes, did you clear them one by one; i.e. going into each module and clearing them; or did you just select the 'clear all DTCs'? As good as VCDS is, one of it's downfalls is that the 'clear all DTCs' doesn't always do what it is supposed to. Using this latest scan, can you go into each module that has error codes and try and clear them, and note down which modules don't clear. Then just list the module numbers that still have errors. e.g. 01,46 etc (01 & 04 will definitely not clear). One final point. Is the TPMS warning light on in the instrument cluster?
Old 11th December 2022, 04:06 PM
Garry1's Avatar
No tpms error on the cluster
I did reset errors individually
A few will not clear will get a look again
Blue
Old 16th December 2022, 10:43 PM
monkeyboyuk monkeyboyuk is offline
Had an issue with mmi in my old d3 and thought was water related. In th3 end it just needed a reboot….. units behind the glovebox, unplugged the cables and plugged em back in and all worked. May be worth a shot….
2014 D4, FL 3.0tdi, phantom black, sport exec lwb
2002 D2 S8, Aqua Blue Pearl, original bar FE alloys and miltek
1997 D2 PF 4.2q, silver, Sport on roughly 90k and counting….
1990 2.3 20v 7a Coupe Quattro
**SOLD** 1996 2.6 v6 cabriolet, Isis red metallic
**DEAD ** 2009 D3, 3.0tdi sport, black
Had a few Audis over the years, mostly early stuff, newest was a D3 prior to my D4, nothing much kept me smitten with other marques so I floated about a bit from one thing to another until that four ring lure caught hold
Old 17th February 2023, 05:48 PM
Garry1's Avatar
Could not get radio or anything going
Then it would just come on and go off
Got sick of trying
And it stayed on for a few days
Then went off again
Eventually found out it was 30 amp fuse in the boot was arcing till it was black and no connection
New fuse and connections cleaned works every time
Next job is getting electric steering wheel adjustment to work and why the power steering is heavy but not massively heavy that you can't drive it
Blue
