Old 10th May 2010, 09:54 PM
I could be wrong maybe my wheel is 9.5J why would Audi mount 275 35 20 tyres to a 9J tyre if the maximuim recommended is 265mm, sureley the millions they spend on development would have flagged that up. Does anyone know what tyre size the D3 alloys are
Because the minimum size wheel for 275/35 is 9"! Where do you get 265 as the maximum recommended size?
Old 10th May 2010, 10:39 PM
Mike, it says you posted on this thread at 10:54 but I can't see your post
Edit: Found it, from the site that Neil posted it says
Rim width
9,0 inches
Min Tyre Width
235 mm
Ideal tyre width
245 ou 255 mm
Max tyre width
265 mm
Old 11th May 2010, 04:50 AM
Wot he said ^^^^^
oh and http://www.tyres-pneus-online.co.uk/...es-advice.html
Old 11th May 2010, 07:08 AM
OK. I love the name pneus online.
I have always used the resource http://www.carbibles.com/tyre_bible.html
Using the rim calculator on page 4 gives 9" as minimum
Old 11th May 2010, 06:44 PM
if you put 285 x 30 x 20 in to your calculator it says you need a 9.5" to 11" wheel mike which is what mine said too - not sure where you got 9" as ok for a 285 from?
Old 11th May 2010, 08:02 PM
Where did 285 come from? I thought we are talking about 275.
I am putting 285s on 10" rims.
Old 12th May 2010, 02:04 PM
£1k later and your all wrong. The 285 tyres went on fine with no problems at all. So I'm now rollin' on Michelin Pilot sports 2, will let you know what they are like compared to Verdistans but apparently, they are the best along with the Goodyear eagle F1s.
285s
Also, this Pic isn't relevant to anything in this thread, but not worth starting a new thread over eitheir so Ima dump it here. Anyway, I noticed today how my alloys look like MTM wheels with the centercaps off. Yes/No?
Old 12th May 2010, 02:19 PM
Also the tyre place were really surprised when balancing my wheels today as each alloy only weighes 30 when most 20s weigh 90! So lightweight too, but apparently that means they are easy to buckle.
Old 25th May 2010, 04:21 PM
Just an update 400 miles on, and 90mph long sweeping curves, roundabouts and many full locks and the wheels are spot on and the car handles like its on rails as I just had another track rod end changed and geometry set up last week. So to all that said 285s wouldn't fit
Old 14th June 2010, 04:41 AM
jayzee jayzee is offline
Nice one! People like you who push the envelope out help the rest of us
