Old 5th August 2010, 07:33 PM
Not sure give Ben at Avperformance a call, he knows.
Old 5th August 2010, 08:02 PM
I have Jetex components on both my 8s and the sound is awesome. If you by the right bits and can weld them up you'll be impressed. I've blogged the build on here somewhere.
Old 5th August 2010, 11:37 PM
jayzee jayzee is offline
Originally Posted by Mr K View Post
whats the difference between a 4.2 A8 exhaust and an S8 exhaust? im litterally about to order a second hand A8 exhaust (standard cat back) as a temporary thing and to buy me some time to cut my S8 exhaust about and repair it.
Here's one http://cgi.ebay.co.uk/AUDI-S8-A8-4-2...item4a99cb3b96
HTH
Yeah baby!!
Old 6th August 2010, 11:53 AM
Mr K Mr K is offline
that was close - i was about to order a 4.2 A8 exhasust as a temporary thing from A8 parts! they have had a dig and come up with a good condition S8 system now.
That will hopefully stop my horrible rattle (although i suspect its the insides of a cat - despite them looking pretty new and just going through an MOT)
This will give me a system off the car to chop around - i have a couple of ideas.
1. The middle box is going around the welds where the pipes go in/out, so i it would make sense to split and bypass this.
2. Repair the rot and put a pair of butterfly valves on a 45degree T just before the back box. Wire theese to a switch inside as per 'sports mode' on the latest RS4's, and to the 'squirt mode' on the shifter. as per theese from Ratsport - http://shop1.actinicexpress.co.uk/sh...ut_trimmed.jpg
But they are £200+ each, and I would obviously need two. Thats too much to go splurgeing on playing around with a rusty old exhaust, so i would need to find them for about half that.
Old 6th August 2010, 01:39 PM
You are getting into the realms of a full cat back stainless exhaust system now money wise.
You have to ask yourself - is it worth it on an old mild steel system?
If you can do what you originally planned for a budget, then fine, but all the other bits and bobs in my mind would be easier to justify in having a bespoke system made by a specialist.
Yeah baby!!
Old 7th August 2010, 05:06 PM
http://www.youtube.com/watch?v=T5RFA...eature=related
Ignore the tail pipes, but the silencer looks to be the factory OEM - possibly did a similar thing to your idea?
Is this what you want to try and achieve sound wise?
Yeah baby!!
