had both split c.v boots replaced last week oil every were would this affect the abs sensors ????
May do if they got covered in it.
Take off the wheels, remobe the disks and they are on the front of the hubs. I'll post a picture tonight.
thanks for your help conan
did a scan today and it showed this
Monday, 18 October 2010, 09:23:12. VCDS-Lite Version: Release 1.0 Control Module Part Number: 4D0 907 389 E Component and/or Version: ABS/ESP allrad D57 Software Coding: 08397 Work Shop Code: WSC 02313 1 Fault Found: 01119 - Gear Recognition Signal 35-10 - - - Intermittent ---------------------------------- |
There should be a corresponding fault on the transmission with that code. If not it could be the speed sensors just need cleaning.
This link has a bit more info.
Picture as promised. Note you may have bolt in sensors not push fit as per the picture. Just remove reinsert with some coppaslip and retest.
transmission scan is coming back clean,would this be pointing me in the direction of the abs sensors
It's not a difficult job and will take them out of the equation.
cheers conan will give it ago tomorrow ,will let you no how it goes
Nick are you still around?
Did cleaning the ABS sensors solve the problem or was it something else. I am getting similar symptoms to you but don't have the ABS light on or any fault codes. The vibration only happens when the car is stationary and in gear (drive). If I put it in neutral it goes away. When I pull away it goes away. I'm thinking it's gearbox/engine mount maybe? Any ideas anyone?
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had ![]() THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again ![]() |
