I finally cured mine by changing the injector.
![]() Quote:
If it doesn't it's the ignition amp. |
Swapped number 6 with number 1 and also put a new set of plugs in,
Number 6 was the one giving the intermitent misfire and when I took the coil pack off the plug it was slightly wet all the others where dry, cleaned it up and sprayed WD40 around and all good at the moment, the misfore started when it was really comming down and going through some big puddles, will check again at the weekend to see if its wet again and if it is might be a gasket/seal issue? |
