Old 22nd February 2011, 04:39 AM
daz.g
Guest
Posts: n/a
I had my rear chrome strip off to replace some clips and it was surprisingly easy - just two bolts kind of in line with the number plate and the bumper slid right off.....
Also, they're easier to clean up when off the car and I found a claying followed by ag metal polish worked really well tidying them up......
Old 22nd February 2011, 07:00 AM
Yeh, thanks! A bit more involved than I had hoped. I'll try the wet & dry approach first
Old 22nd February 2011, 08:16 AM
To get the door trims off there is a screw on the inside trailing edge of each door. Remove it and slide the trim backwards.
Once of its just a case of twisting the clips on the inside with some needle nosed pliers and the trim will come away.
The cost to replce all the trim on a PF is almost £800 of a FL it's £970 Audi retail.
