Old 9th April 2011, 09:55 PM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
I use nitrogen, I have noticed the fuel economy is better. Makes a difference in my trade. Not so sure it would be that useful for vehicles that aren't used frequently.
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Old 9th April 2011, 10:43 PM
thats what I call gas lift suspension!!
Old 10th April 2011, 06:37 AM
darrenjoe90's Avatar
In theory (if I wasn't conned) I have nitrogen in all but the O/S rear.
No difference I can detect and no difference in temperatures during use.
I was conned wasn't I. He didn't put nitrogen in did he
Now I've got to try Kwik Fit, so I know. A fiver sounds so cheap, was that the lot or per wheel?
its £1.50 per wheel or £5 for all four doing
Audi S8 Phantom Black
Old 10th April 2011, 08:56 AM
I got Kwikfit to put Nitrogen in my tyres a while back - it seemed to give a small but definite benefit to ride and economy, but I notice it less now (either because I take it for granted, or because I was imagining it!!)
Old 10th April 2011, 01:16 PM
I just want to check if the numbers look right.
As per wikipedia, Nitrogen density = 1.251g/L
Air is 78% Nitrogen, 21% Air, 1% Argon, average density = 1.294g/L
I dont know if my calculation is right, a 245/45 18" tyre at 35psi holds 93l of air.
So, the weight of air in a tyre vs weight of Nitrogen in a tyre is:
Air = 93x1.294 = 120g
Nitrogen = 93x1.251 = 116g
Weight saved = 4g. but, because rotating mass is like saving 2.5x static mass, thats a saving of 10g.
I doubt anyone would feel that.
Old 20th April 2011, 09:41 PM
I'm uncertain running on curry emissions is better than nitrogen. Unless you're using is a fuel
Old 22nd April 2011, 11:18 AM
FireStorm FireStorm is offline
im defintaely going to give this stuff a go when my drift car is back on the road.
when i say the back tyres get too hot to touch im not making it up
you cant touch the wheel as you will burn your hand its that hot.
i know the nitrogen wont cure the heat on tyre and wheel, but it will stop my wheels going to like 70-80psi during drifting
Old 29th April 2011, 03:31 PM
Night Train's Avatar
Would the tyre pressures be the same as manufacturers spec when using nitrogen?
Also is there a different pressure required for faster driving, how's this affected by nitrogen or vice versa?
£1 per tyre here at ATS
Other vehicles
Oh Yes....... The '98 PF S8!
Old 7th May 2011, 07:42 PM
E.L.M.O's Avatar
E.L.M.O E.L.M.O is offline
Tristar Worldwide Chauffeur services use it in all their cars.
A8 Sport '99 4.2 V8 STOLEN 19/01/12
'92 Mini Mayfair (Sold)
'80 Mini shell + V5 (for Sale)
'72 Mini Pick up Supercharged 1380
'03 S4 Avant
Old 10th May 2011, 09:23 AM
FWIW, aircraft (well, large ones anyway) only use nitrogen for tyre inflation.
I think the reason is that N expands less when heated, thus the tp stays constant after very heavy usage. Aircraft wheels/ tyres get very hot and 'work' extremely hard. The tyres wear out quickly and get changed frequently.
It's not to do with leaking through the tyre (or elsewhere) because the pressure is checked and adjusted daily.
It might be because Nitrogen is 'drier' than air. Air's always got water in it.
I'll ask an engineer.
