Old 23rd June 2011, 03:42 PM
well it worked a treat and im still working on a faster dry time for the carpets as the 3 inches of foam soaks up a bath full haha
Old 23rd June 2011, 04:30 PM
m3csl m3csl is offline
thanks for the top tip will be doing that this weekend.
m3csl
Old 23rd June 2011, 06:42 PM
Guess you will still need to unblock the drains as well or it will just fill up again?
Old 23rd June 2011, 06:57 PM
no problem, and yes the drains under the H vac blower motor still need to be cleared i used the audi pages way that mike discribed over the phone for me, i still need to investigate Botangs hole near the ecu tray just to be extra sure the misses wont be having a foot spa on the move again haha
Old 23rd June 2011, 08:26 PM
have you done the orange ones in the tranny tunnel as well?
Old 23rd June 2011, 09:07 PM
i had done them a while back but im fairly sure the cause was the 4inches or so of water in the scuttle area under the bonnet by the H vac, it was however in all the vents in the rear ect.. so i may well check that out at some point to make sure it all stay's dry
Old 16th July 2011, 04:28 PM
roboblob roboblob is offline
My Aircon has started smelling of stale water just as it starts up ,you think i have a drain hole prob ,though my car does leave a nice puddle which appears to be coming from the orange tube position ,but only on the drivers side.
Old 17th July 2011, 02:44 PM
orange drain pipe yes, by any chance if you turn the air con on for 5-10 mins then manualy select econ mode shutting the ac off then tell me what it smells like if it only smells bad when it crosses over from ac to econ then its the orange drains
Old 17th July 2011, 05:34 PM
ok will give it a go when i am next out thanks
Old 17th July 2011, 10:54 PM
also forgot to ad that when you test it do it with ac on low
