Old 2nd August 2011, 09:17 AM
should you need a scan i get across to Warrington fairly freqently, but there may be someone closer
Old 2nd August 2011, 09:30 AM
engine85 engine85 is offline
I have settings elsewhere, but not related to the fingerprint/memory setup, the car suspension settings should also be under the same menu option, the warning lights come on at start up then extinguish as expected.
If i actually press the fingerprint reader, its says 'not recognized' but nothing happens.
Old 5th September 2011, 06:15 PM
Returned the car after finding a huge list of faults, its now posted on auto trader after someone bought it on e-bay for less than £4500 . .
http://www.autotrader.co.uk/classifi...51ya?logcode=p
It does'nt have sat nav, bose or phone prep, the rear diff requires replacing, the fingerprint reader is not working and locking you out of the suspension menu, the discs/pads all need replacing, the tailpipes are still a differant size and the engine 'hunts' constantly, the abs computer has a fault and various bits of trim are missing/broken . . . but the coil packs are new. Beware
Old 6th September 2011, 07:00 AM
sloss's Avatar
sloss sloss is offline
Not a good motor at all. Glad you got out of it OK
