Old 24th February 2009, 07:02 PM
Yes extremely durtyyyyy
Why do I have the feeling yours will look like that shortly
Old 24th February 2009, 07:31 PM
Interesting that 305/25-19 will do wonders for acceleration as when the speedo reads 70 you'll be doing 65!
Still want one!
Old 24th February 2009, 08:22 PM
A8_Tony's Avatar
A8_Tony A8_Tony is offline
Above is something which will give you an idea as to how your rims would look. Not perfect simulation, but the best you'll get without photoshopping it.
I run 10mm spacers all round, with ET35 rims, and find that they sit exactly where I want them to.
ID:	78   Click image for larger version
ID:	79   Click image for larger version
A8OC Founder
The A8 Owners Club here
Old 24th February 2009, 09:52 PM
Ska's Avatar
Ska Ska is offline
What width are your wheels Tony? They look a lot wider than 8"
Old 24th February 2009, 10:09 PM
A8_Tony's Avatar
I'd have to check fella. Believe they're only 8.5, but they might be 9" wide. The 255 tyre seems to have a little stretch on it in some pics
A8OC Founder
Old 25th February 2009, 07:02 AM
If anyone wants any spacers, we've currently got a set of 10mm, 15mm and 20mm inc longer bolts etc - everything you need to get them on your A8 if you want that 'wider' look..... Email us enquiry@a8parts.co.uk if you're interested.
Old 25th February 2009, 08:08 AM
Ska's Avatar
Ska Ska is offline
Two Q's Ian:
Are they Hubcentric?
And are the bolts tapered (aftermarket wheels) or spherical (OE wheels) seating?
