Old 15th April 2012, 04:12 PM
47p2's Avatar
47p2 47p2 is offline
Default How to prepare a 65 year old car for its MOT
Well I decided it was time to get the Rover ready for tomorrows MOT so I started her up for the first time in 8 months
A couple of turns of the starter motor and she burst into life, and round to the back of the house for the preparation work which consisted of a bucket of soapy water and a hose.....That's her now ready and I'll see what tomorrow brings.
I don't need to check wipers, seatbelts, indicators, brake pipes or brake cylinders for leaks, screen washers, emissions...In fact there is very little to check and I think I should get a cheaper MOT as it won't take much more than 30 minutes to get everything checked
Nite Blue 3.0L SE Quattro
Old 15th April 2012, 04:15 PM
Thats such a cool motor!!
Old 15th April 2012, 04:20 PM
47p2's Avatar
It will be if it passes the MOT
Old 15th April 2012, 04:23 PM
8 months without starting??..
Are you not afraid that open valves could start rusting? I guess it is less of risk if kept in heated garage but still..
As far as I know it is not recommended to leave engine without starting for more then 3 months and that is for petrol engines with fairly fresh oil. Diesels and engines with older oil should be started and run even more often.
Old 15th April 2012, 04:28 PM
47p2's Avatar
I turn the engine over every month with the starting handle, a great work out and keeps me warm in the winter months
There is a radiator in the garage to keep everything toasty warm.
Old 15th April 2012, 05:38 PM
beautiful, do you have any interior shots
Old 15th April 2012, 07:16 PM
47p2's Avatar
Plenty interior shots...Where to start!!!
Rover didn't do wood, they did tree trunks
Rover were supplying rear blinds way back in the 40s as standard fittings
Air-con provided via the sunroof and opening front windscreen
