Old 26th August 2012, 03:19 PM
elvis elvis is offline
is any posibility to scan without using mechanical
pc ?
Old 26th August 2012, 03:37 PM
There are aftermarket standalone units but they mostly do engine only or you can get old dealer VAS5051 but they are costly. Best option is to buy PC cable and use it with PC/laptop. I mean you have PC to post on forum, just buy VCDS interface cable, you can get them on e-bay for less the £7 http://www.ebay.co.uk/itm/VAG-GROUP-...ht_4444wt_1163, where is the problem?
Old 28th August 2012, 07:45 PM
ainarssems
and the softwere where can i find .if i find soft i must diagnose it by myself
Old 28th August 2012, 08:05 PM
Originally Posted by elvis View Post
ainarssems
Usually you get VCDS software with the cable or you can download shareware version here: http://www.ross-tech.com/vcds-lite/download/index.html or You can use VWTool software which I can e-mail if required. Once you get fault codes from car it should give more clues about fault.
Old 28th August 2012, 08:10 PM
ok send it to me via email @ elvisbuli@hotmail.com
Old 28th August 2012, 08:48 PM
Also have a look at this it will help you to understand how it works and also give you ideas how to use FWD only. Sorry it's German but al least you can check pictures and diagrams. It's for 4-speed gearbox and I think yours being 1995 is probably 4-speed but even if is 5 speed principle is the same.
Old 28th August 2012, 10:14 PM
email to you came back as undeliverable so here is VWTool
Old 30th August 2012, 04:09 PM
ainarssems thnx for the material but it couldnt be open
it looks like an error file
it was a .exe but must be a degaged file
Old 30th August 2012, 05:31 PM
@;ainarssems
finally i opened the material but the difference is thet the transmission here is notlike mine
my transmission is a tiptronic yonger than this in document
Old 8th September 2012, 11:09 AM
Default hi
Architex_mA8tey
i think tha my problem of tronic is the transmission compiuter because and the signs of transmission report in panel do not apear
