Old 13th November 2012, 06:16 AM
sloss's Avatar
sloss sloss is offline
I gave up trying to suss out the boot lights. Changed all bulbs to LEDs and they stopped working all together!
I now have the closest one as LED and the other 2 festoons and it all works OK.
If I remember I'll stick a grandwean in and see how long they take to go out
Old 13th November 2012, 07:31 AM
Mine are all (3) LED and work fine.
Old 13th November 2012, 07:43 AM
sloss's Avatar
All to do with timing.... I think
Old 13th November 2012, 09:02 AM
oldnick oldnick is offline
No switches I know of, are you looking at the black cushioning springs?
Screws have felt-covered heads, look harder.
cushioning springs !!!! no wonder that they don't turn the lights out
so what switches the lights on when you lift the boot lid ? maybe a mercury switch like the bonnet on my 5 cyl 20v
but then the lights would go out when I shut the lid ...how do I find out if they do
could be there isn't a timer after all [ as I said before , can't see a logical reason for one ], and the problem is just a faulty feed or switch , sometimes the lights come on and sometimes not , also why the lights will go off after a long time
maybe you have the right idea sloss , if at first you don't succeed ....give up ; what's a grandwean anyway ?
Old 13th November 2012, 09:37 AM
I think there's a switch linked to the boot catch somehow.
No doubt someone here will have the details, I've no idea where it is.
Wean - scots for child.
The microswitch is in the boot catch itself for the lights if I remember rightly.
Old 13th November 2012, 10:14 AM
as they say where I live ....voila !
the microswitch IS indeed in the boot catch , opened boot , quick spray of silicon oil , locked /unlocked it a few times [ unlocks by pushing the button as usual ] , lights come on every time !!!!
even more important I shall be able to pursue my search for a current leak by lifting the lid and locking the catch to put the boot lights off so no current drain from them
and HP ....I opened the barn door a bit wider to let in today's brilliant sunlight ....and found a lot of well disguised screws ; funny that
thanks to all for your help
