Old 8th February 2013, 10:02 AM
If its heated, then its already heat & UV reflective....
GPS signals seemed a big problem on Earlier D2's, particularly the PF, but later 8's i've never had an issue with...
Old 8th February 2013, 10:50 AM
Re-radiating GPS antennae are fairly cheap, Mike was using one for a bit and it did the trick.
Old 8th February 2013, 12:47 PM
My FL D2 with heated screen is pretty nigh impervious to GPS signals - which is not surprising as the metallised coating used for the windscreen heating element and for IR shielding in the double pane windows provides very effective electromagnetic shielding at the GPS signal frequenicies (12-1500Mhz) and power levels.
