Old 11th February 2013, 06:54 PM
ash_a8 ash_a8 is offline
it works fine in reverse and 2nd and if i put it into triptronic i can put it into 1st and is fine i can nail it and doesnt slip in them gears soon as i put it it drive or 3 or 4 it just revs up but can smell a dodgy smell so could it be electrical?
Old 11th February 2013, 07:03 PM
mannyo mannyo is offline
The dodgy smell is most likely the transmission fluid overheating and burning. Not good for the fluid at all, and it will now for certain need changing.
I had a slipping brake band in an old Mondeo Automatic, got it fixed at a transmission specialist for £300 including new fluid. The symptoms I had though was total loss of second gear and a slipping overdrive. Driving everywhere with just 1st and 3rd was not fun as it would rev to the red line before changing straight from first to third.
Manny
Past
Old 11th February 2013, 07:53 PM
it hasnt been driven far like it but ill see what they say tomo and see about gettin filter and fluid changed if they think thats what it is
Old 11th February 2013, 08:08 PM
RanjS8 RanjS8 is offline
Default Slipping gearbox
From what you are describing this really does sound like an internal issue since 3rd and 4th gear aren't transmitting drive...I would hope the f125 switch is buggered....cos usually low fluid causes thumping and dodgy gear changes....but i hope for your sake it is just fluid that you need....
Old 11th February 2013, 09:35 PM
ive been speaking to a few people and a bloke who has a few a8s that maybe is on here said he had similar problem because the ecu was wet and shorting under the bonnet, the car was steam cleaned and wash out all under the bonnet so i think this may be it also under the passenger seat is wet were they did carpets it not coolant as hasn't used any so fingers crossed its ecu problem or oil as love the car
Old 11th February 2013, 09:37 PM
its 5 speed so 345 that wont work but 1st and 2nd are perfect but it wont let me go 1st to 2ns on triptronic only 1st i then have to put it in2nd under drive so seems weird
Old 11th February 2013, 09:40 PM
Gearbox ECU is I think the top one in the box by the bulkhead on the nearside under the bonnet.
Getting the cover off to check inside is fairly easy (just a few screws) though sometimes the sockets they fix into just rotate in the plastic they're set in so you need to be careful.
Old 11th February 2013, 09:43 PM
could this cause it to mess about if there wet due to them soaking everything
Old 11th February 2013, 10:54 PM
sarg sarg is offline
the gearbox is gone - the symptoms, the smell, it all point to a failed gearbox. Since when do wet electrics (a) smell or (b) work at all?
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 12th February 2013, 07:39 AM
Water in the cabin is a common A8 fault to do with evaporator drains. Nothing to do with the gearbox.
Its a hugely slim chance that water has ingressed into the plenum chamber, and affected the ECU, thus affecting only gears 3/4/5
Its fractionally more plausible that some transmission fluid has leaked out, burning on the exhaust and causing low fluid, but to be honest low fluid would affect gears 1/2 just as much as the others.
Given the age, mileage and symptoms, number one in my book is still a terminal mechanical failure inside the box, sorry.
Take it to an automatic transmission specialists - Not a generic garage - They will see ZF boxes all the time and should be able to give you a good idea, fairly cheaply of whats going on....
