Old 23rd April 2013, 04:15 PM
Sorry mate you're going to have to make this really simple for me. Are we talking about realy 382 that the finger is pointing at, or are we talking about the relay that is missing but circled?
Old 23rd April 2013, 04:31 PM
RanjS8 RanjS8 is offline
Default Solar relay
It is the relay that is circled but missing
Old 23rd April 2013, 05:32 PM
B@fink B@fink is offline
I know you said not to say it but.............. they need the sun to work. Wait till its sunny. Be like a galeforce 10 in there
PF late '97 D2 2.8 Aluminium Silver. Solar roof, Full Heated Leather, Double Glazing, 17" wheels, Sports Steering Wheel, Cruise, Blinds, Bose sound.
Fiat Tipo diseasel econobox with all the buttons and none of the soul that now does all the heavy lifting.
Ford Capri Laser: noisy, slow, thirsty, bouncy, no buttons but it always sounds like it’s REALLY trying and I can’t help but chuckle when it parps and boings along. And people of a certain age stare at it with a wistful look in their eyes that clearly says…I had one of them. And I sold it because of the kids
Old 23rd April 2013, 07:53 PM
Thanks Neil jim's going to be along now soon and clear this whole thing right up for us.
Not at all, my master electrician did that for me! Thanks Richard!
Old 24th April 2013, 06:12 AM
Thanks Ranj, i hate electrics
Thanks mate, although just for the record i'm not quite that retarded, and i had worked out it needs the sun to work. It has been beaming here last couple of days.
Top banana's thank you, i'll ave a look at it a bit later.
Old 24th April 2013, 07:20 AM
Yeh, Brian and I (and Gordon?) are looking forward to coming south to the meet in The Forest of Dean so we can check if our sunroofs are still working!
Old 24th April 2013, 07:59 AM
Relays are pretty robust, as are the contacts on the sunroof itself.
As an outside idea, maybe your blower motor is getting on a bit, and whilst a good battery will make it spin, perhaps the southern sunshine is not good enough any more ?
You can take the cover off the top of the blower motor chamber under the bonnet and find the conenctors for the blower motor easy enough.
On a sunny day if there is some voltage at this connector then everything is working as should. If not, then start to look at relay/wiring/contacts/sun
Old 24th April 2013, 08:38 AM
Thanks Ian, i don't have a multimeter to check if there is power getting to the fan but i should be able to hear it running with the bonnet open.
I have replaced the fan once with one from A8Parts so should be ok, as it would spin faster on cornering and i put that wear down to the fact it had solar and was running a lot of the time or at least more of the time.
To be honest i'm not ripping the car top bits trying to find the problem, if it's not simple then it will just not work.
Just wondering have A8Parts noticed a difference in the condition of the leather form cars with solar and those without? Just wondering if the one's without dry out and crack more? Hard to tell i suppose as can't tell if the leather has been conditioned regularly
Old 24th April 2013, 09:47 AM
That may be your fundamental error.... Its virtually unhead of for the solar roof to spin the fan fast enough to actually hear it.......
On a very sunny day, you should just feel the light waft of air coming out of the centre vents...., unless you have a broken flap or something..
Old 24th April 2013, 09:53 AM
I must have the "turbo" version then. It bursts into life at the slightest hint of sunshine even in midwinter which isn't always welcome.
Right now I can easily hear the fan from outside if I lean over and put my head near the base of the windscreen.
And inside there's quite a breeze out of the centre vents and a "waft" elsewhere.
The PF I had before (now yours Ian) wasn't quite as purposeful though.
