![]() Quote:
![]() Quote:
http://www.imcdb.org/vehicle_5749-Au...p-4D-1999.html |
If the pump isn't installed properly and runs dry then it can draw too much current for too long and burn out the fuse.
![]() Quote:
Richy - Good effort, but that's a facelift. Thanks, Dave. Will look in to what I need to do to calibrate via VAG COM, top stuff. ![]()
Depends on the kind of garage that did the work to date - if a main dealer they probably went for the 'well that doesn't work as intended so we'll change it for a new one and see if it fixes it' rather than following a logical fault finding exercise that'd probably cost more in labour than they could justify charging.
Potentially a day with a decent specialist would sort it if they can work through from first principles. To confirm the switch is duff you need to know which pin on the back should be doing what and at what time in the starting/running cycle
If it's run and then cut out at least the switch was working then, even if intermittently. That pump assy is a mare to get seated properly, even whan it looks to be right. Worth undoing the fuel rail and switch it on see if it blows fuel everywhere, should be able to get a pressure reading up there too.
Is the pump fuse shared buy something else too if i remember rightly? If not the pump drawing too much juice could be the something else maybe?
1996 A8 4.2 QS. Bose, Solar roof, um...um... rally sport towbar. Now gone to a new home as the Traders 8. Bright yellow bus o love. |
Welcome back Amar
![]() (Not as if I'm a regular anymore myself but still like to pop in from time to time to see what's going on ![]()
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten ![]() |
