Old 12th September 2013, 06:16 PM
The Trak+ ones from H&R seem to be universally popular - have you decided what size you want?
I got a cheaper price from euro car parts if you do decide you want those
Old 12th September 2013, 09:40 PM
Norretal's Avatar
Norretal Norretal is offline
I fitted MTM spacers after buying them off a forum member. I'd fitted the 20" wheels and thought they looked great but had seen other cars on here with spacers fitted and couldn't resist trying them myself. I've got 15mm on the rear and 10mm on the front and I think it gives the stance that little bit extra. I've heard the rear end rub a couple of times when the boot is loaded and the I've hit a dip on a B road but that's probably due to me having 275's fitted.
They fill the arches much better with them fitted in my opinion, I can post some before and after pics if required.
Audi TT - 2015 - Ultra
Old 12th September 2013, 09:46 PM
Originally Posted by Zip View Post
Would anyone recommend any particular manufacturer over others? Bit worried about the wheel wobble comments in this thread.
Thanks,
Zip
I'd recommend H & R trak+ hubcentric spacers, great quality and very precise well made kit which you can bolt on with the bolts supplied into your hub and then use your original wheel nuts with
http://www.trakplus.com/
Old 13th September 2013, 06:01 AM
No rubbing issues with my spacers either
Old 13th September 2013, 08:00 PM
Is that cos your car hasn't moved for 2 weeks whilst you show that lovely Aygo some Lairdy love?
Old 14th September 2013, 06:08 AM
Oli18's Avatar
Oli18 Oli18 is offline
Hi - I went down the H&R route and love them.
I have the 20" FE D3 wheels so 9J....20mm on the back and 15mm (Eibach pros) on the front.
You can see the pics here...
http://forum.a8parts.co.uk/showthread.php?t=2050&page=4
Oli
Audi A8/S8 D2 Flickr Group
Old 14th September 2013, 06:40 AM
My car hasn't moved for a month!
Old 14th September 2013, 06:50 AM
That's useful to know Oil - looking at comparative specs on D2/D3 20s it should be the case that without spacers you have 7mm less clearance on the inside and the wheels stick out 5mm more on the outside, so with your spacers and 8.5" rims they'd sit 5mm further in than in your pics.
Sounds like there should be no rubbing issues with 20mm on the rear anyway
Old 14th September 2013, 01:59 PM
Norretal's Avatar
I'm intrigued now, I wonder why mine occasionally rub despite having only 15mm spacers on the rear? Could it be the extra tyre width (though I'm sure others have 275's on 20's?) or the shorter (by 40mm) springs? I've checked with a straight edge and they're close but shouldn't catch but it may be when the springs are compressed hard and it's the inner arch that's making contact with the tyre? They're 9J wheels so I assumed they're the correct fittest?
Old 14th September 2013, 02:30 PM
Standard d2 s8 spec 20s are 8.5" wide so yours are d3 a8 wheels if they're 9"
Even so Oil has his wider than yours so depends if its catching on inside or outside?
Stock tyre size for 8.5 is 255/35
