Disconnected the battery and left on trickle charge for most of today and it works
![]() Have connected the solar trickle charge via the cigar lighter socket so lets see how it goes...
Andy. Current cars: BMW i4 M-Sport Peugeot 207 (the sons) Triumph Daytona 675 (2017 reg) =========================== Gone but not forgotten Ford Focus ST-2 Mk3 (the wifes) (stolen Oct 2023) 1972 T2 Bay Window Camper (Slow) Audi TT Mk1 225 - now with coil-overs and a 7inch touchscreen infotainment centre 2003 A8 Sport 4.2 (with ACC & LPG) (Feed up with all the issues so passed it on to a forum member) 2000 A8 FL QS 4.2 (with RNS-E - Nice ![]() |
FYI - The solar charger through the front cigar lighter works
![]() So, no more drained battery when I leave the car for long periods. Cheers
Thats a stroke of luck.
Got any specs for it?
Del ![]() |
Result.. Is the keyless all working properly again too?
Nope
![]() Will get in touch with Audi and book it in to see if I need the update that Nick had on his.
If you've got power again, do a VCDS scan and see what errors you have (if any). And check the carpets (probably underneath them too).
![]() Quote:
In the MMI, the battery shows as less then 10%, but with a multimeter it has 12 volts....... Think this is what Nick had - when everything works the MMI shows battery as good, but when things don't work, MMI shows battery as bad even though battery shows plenty of charge. Will check the carpets though ![]()
let me know if you want it scanned
A8 4.2TDI - Ice Silver, Comfort heated/cooled/massage Seats, Alcantara, Extended Leather pack, Ambient light pack, Solar roof, Night Vision, Lane change assist, Audi presense, Audi BrakeGuard, ACC Cruise, Blinds, Quad Air, AMI, Online services, Parking with rear Camera, Aluminium brushed inlays, Adaptive Zenons, High beam assist, Bose Sound, and more Gone but not forgotten: A8 D3 2005- AMI HDD, Audible Parking, TV, NAV, Bluetooth, Hybrid TV, Aftermarket headrest monitors, Rosstech VCDS / Vagcom |
If you update MMI beyond a certain point it turns the battery meter off as it basically doesn't work properly
Mine has showed 75% a few times
