Old 11th December 2013, 05:54 PM
mannyo mannyo is offline
Default VCDS scan of my D3 before and after fault code clear
Some fault codes have remained.
The attached files below are:
Before.txt , contains the full scan before clearing any codes.
After.txt, with the exception of the first bit contains the fault codes which remained.
The before has lots of faults because the battery was not well and replaced yesterday.
Do any of these look critical? There are only two that remain. One to do with the parking brake, and another to do with the alarm.
Manny
Past
