Old 12th February 2014, 05:21 PM
Default Headlight Symbol Illumination LEDs
I just replaced the second LED in my headlight switch.
The green sidelight on one blew 2 years ago, yesterday the orange Auto one blew. I was able to desolder the old ones and put in some new ones that were slightly smaller, but a good replacement.
Remove the switch by turning knob to 0 then pushing the knob in 1cm and turning to first position, this should cause side pins to withdraw and then it cab be pulled out. You can then unclip with fingernail or similar in the end edge of the connector.
3 screws remove the back of the switch and the PCB lifts out and the LEDs are on the other side.
The orange Auto one is bigger, I had a small one and it is not quite so bright.
It's still OK though.
The parts to search ebay etc.. for are "yellow 0603 led" "yellow 0402 led" or whatever colour. The number refers to the size in mm, not sure if 0603 is better, I used 0402 and they were a little small.
Old 12th February 2014, 06:38 PM
Nice one, thats the kind of thing I love to see.
Most people would either put up with it or replace the whole switch.
Old 13th February 2014, 04:19 PM
Same here, great stuff
I may have to do something similar soon as I lost all the illuminating bits above the chrome horizontal bar running across the dashboard including buttons on the chrome bar.
Visit card tray, vents etc, all dead.
The only bits which still lit are the hazard lights button, ESP on off and parking sensor I think.
Old 13th February 2014, 05:23 PM
Probably a 1A fuse that has blown, I replaced mine with a 2A and i't not gone again since
Old 13th February 2014, 08:08 PM
Laziness and situational stupidity sometimes has no limits.
Just changed the SB29 and it's like a different car, CHEERS Paul
One question tho, I have no 1A or 2A fuses so I had to stick 5A, would it matter a lot, can something bad happen if there is a problem which blown the fuse on the first place??
Old 13th February 2014, 09:12 PM
Oli18's Avatar
Oli18 Oli18 is offline
Nice one
Can the moderators make this a sticky possibly?
Oli
Audi A8/S8 D2 Flickr Group
