Old 5th April 2014, 08:13 PM
gninnam gninnam is offline
Default Car no longer recognises the key
Help
My car has keyless entry and engine starting and since I changed by car battery some months ago it no longer works
Is it a VCDS session to get it recognised or is there a process that I can follow??
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 5th April 2014, 08:16 PM
I haven't done it myself, but have you tried maybe Adaptation??
Check for DTCs as this may tell you if its just wrong settings or a malfunction
Old 5th April 2014, 08:18 PM
OK - though I don't have VCDS Tend to rely on Limoncello)
Andy.
Current cars:
BMW i4 M-Sport
Old 5th April 2014, 08:19 PM
Where are you based??
Old 5th April 2014, 08:27 PM
A bit to far - Leeds way
Andy.
Current cars:
BMW i4 M-Sport
Old 5th April 2014, 08:39 PM
OK, then this should help you at least a little.
PM me your address and I will send you (gift) a spare cable I've got.
It's not a Ross-Tech one, it's a VAG Commander Full, but at least you'll be able to read the DTCs.
I'm sure you'll be able to do more than that, but I never managed to explore this cable and software fully.
You can download software here:
http://www.resettools.com/vag_can_commander_5.1_full
AS far as I remember, you can't use it on a laptop which is connected to the internet, but software doesn't need install so you can keep it on a USB stick and all you will have to make sure is remember to switch off all the internet connections before plugging in the USB stick and running the software.
Old 5th April 2014, 08:53 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Did they code the new battery in to the car?
Not sure what issues it would cause not coding it.
[center]
06 3.0TDI Quattro:
Options:
Old 5th April 2014, 08:59 PM
When my battery died, car was completely dead, no life whatsoever, I didn't fitted one for over a day or two and nothing was lost. I actually forgot to code the battery for the first couple of months and still everything was fine.
Old 5th April 2014, 09:07 PM
New battery was coded so not the issue
Andy.
Current cars:
BMW i4 M-Sport
