Old 7th April 2014, 01:19 PM
If the discs have a lip, then that'll usually wear through to the sensor before the pads are done, and they do tend to wear on the inside a little more than the outside (or at least it looks that way to me).
Old 7th April 2014, 01:52 PM
Lyons Lyons is offline
If that is the case and the discs need replaced, does that mean the pads are goosed because the edge has been worn to the sensor?
Old 7th April 2014, 02:00 PM
If you're doing discs, then you'd need to do pads as well.
