Old 14th May 2014, 06:25 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Two hours later, 2 battery removals and refit plus some time on VCDS and I found the issue.
Two snapped teeth on a cog.
No idea when or why this happened.
Part of my thinks it was when I plugged or unplug the cables and it confused the motor, it spun up and snapped the teeth.
At least I found the issue, I just need to get it fixed.
I doubt I can buy the needed cog so it's back to A8 Parts and see of they got a motor.
[center]
06 3.0TDI Quattro:
Options:
Old 14th May 2014, 06:38 PM
Good job Scott, shame it's that not a spring or something simple
By the way, great info Random Guy
Old 14th May 2014, 09:25 PM
Grrr. If this was 2020, you would just 3D print a new one using a solidworks file you downloaded from a solidwork sharing site.
Old 14th May 2014, 09:27 PM
Not a bad idea, I could have sketched one up in solidworks if I had it here
Old 15th May 2014, 06:40 AM
ScottD3's Avatar
My mate's dad has a 3D printer, so its an idea but at the moment my boot don't shut very well.
It latches and shuts but not all the way.
Delboy, If you want to solidwork it. I'm more than willing to send it to you and see if my mates dad can print it out. Be interesting.
My randomly unplugging cables is the reason this broke I think.
O well, one to chalk up to making sure that I always remove the battery when unplugging things.
The amount of error codes I had was mental.
Just emailed A8Parts for a price on another motor.
[center]
06 3.0TDI Quattro:
Options:
Old 15th May 2014, 08:22 AM
Yeah stick it in the post, it will interesting to see the 3d print outcome.
I'll PM the address.
Old 15th May 2014, 08:28 AM
ScottD3's Avatar
Brilliant thanks.
Just double checking with my mate he still has it, what format and he's happy to do it.
[center]
06 3.0TDI Quattro:
Options:
Old 15th January 2016, 01:47 PM
ulfilias ulfilias is offline
Opened my boot.....and it now won't lock. Comes down on the button. Goes down and then springs back up!!!
I've tried a screwdriver in the catch mechanism (on lid) and it seems rather weak, though dont know how to get to the mechanism yet (boot lid liner removal?)
I've had the catch plate (on the car, above bumper) loose, have sprayed and cleaned and tried various positions with no joy!
Any pointers???
Lee
Old 18th January 2016, 03:03 PM
Hi There,
Just solved my problem....I had a very weak latching mechanism which i suspected wasn't correct, you could use a screwdriver as the pin (staple) and trigger the catch, but then you could pull it back out quite easily!
Just took the latch off (remove boot trim, via the pdfs in the tech dump) and it looked a little splayed on the end, quick tweak in the vice and it closed up and made the latch less wobbly and it now catches firmly. Re-install and i have a working boot that pulls down and locks properly
Old 30th January 2016, 09:36 AM
mannyo mannyo is offline
I fixed the boot on mine today and for the first time in 2 years it closes and does not pop open again. Took the rear trim piece off and found the spring broken from the soft close mechanism, located the OEM spring but it had snapped. I purchased the multipack of springs from Maplin last weekend, and used one of those to replace the OEM one. The spring is the one shown in post 3 of this thread from audiworld.
http://www.audiworld.com/forums/a8-s...ishar-2866079/
Manny
Past
