Old 16th May 2014, 12:58 PM
mannyo mannyo is offline
Default Mirror glass removal
I have some replacement mirror glasses to fit in place of the golden and failed old dipping ones and the new ones are used genuine ones.
I cant for the life of me seem to get the currently fitted ones to unclip from the holder, can you advise how I can achieve that without breaking the current mirror and fluid leaking everywhere.
Manny
Past
Old 16th May 2014, 01:04 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Tilt the glass alway the up as far as it will go.
With a plastic tool of some sort, gently prise the glass away from the motor at the back.
Keep your hand in front just in case it springs off and takes some cables with it.
[center]
06 3.0TDI Quattro:
Options:
Old 16th May 2014, 01:09 PM
Here you go
Old 16th May 2014, 01:11 PM
ScottD3's Avatar
We could do with a central repository for all theses PDFs.
I got loads of space on dropbox if you guys want to use it.
[center]
06 3.0TDI Quattro:
Options:
Old 16th May 2014, 01:37 PM
Its funny you say that because I was thinking the same thing and extracting all the pages to pdf's from the manual
Old 16th May 2014, 07:06 PM
Funny you both said that
I was thinking same thing some time ago, but I didn't want to suggest and put all that work on Del's shoulders as exporting all the manual to PDFs is probably a very time consuming job unless you can do the whole manual in separate files with a click of one button.
So, every time Del posted a PDF I just downloaded it and started to collecting them in one folder Audi PDFs
Cheers Del
Sometimes is just much quicker to open a PDF than go through Elsa
