Go Back   A8 Parts Forum > A8 D4 > D4 - Engine Bay
D4 - Engine Bay Everything under the bonnet
Old 21st June 2014, 12:15 PM
Stevie Stevie is offline
Default Oil Service
Ok, the warning came on ... Can't see what the big deal is to change the oil. So off to my favorite, Kwick Fit ...
They did the change, but I noticed the guy on the diagnostics terminal so I popped round. He was saying I think this has worked. I got on the MMI and showed him the service setting, reset nicely no problem.
Switched to the Oil level .. Oh dear, overfilled. So fair dues, he immediately shut down the engine, tried to suck some oil out, no go as their oil sucker pipe was too big. drained some oil down through the sump plug and topped it back up.
Everything A OK.
Apparently their manual says 8.2L but in reality it should be 7.5L with a top up. So watch out for that one.
Anyway ...total bill for the oil change = £53
So I'm happy with that.
Old 23rd June 2014, 11:44 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Kwik Fit for a oil change on a D4?
[center]
06 3.0TDI Quattro:
Options:
Old 15th July 2014, 01:57 PM
Why not? it is only oil a filter and a new washer?
Better than £300+ from Audi.
Old 15th July 2014, 01:59 PM
ScottD3's Avatar
That is true but they did over fill it.
I would not KW with a BMX.
[center]
06 3.0TDI Quattro:
Options:
Old 15th July 2014, 02:22 PM
And who knows what quality oil and filter they used. Besides that oil service at dealer is just called oil service but includes many other things they check and lubricate
Edit: Not specific to D4 but this is example service checklist for older Audi's on Longlife service intervals. Now it's all online and computer prints out joblist depending on model, previous service history and mileage, time since last service.
LongLife Service
Every 60,000 km
In addition to LongLife Service:
Multitronic gearbox: renew ATF
Every 90,000 km
Toothed belt and tensioning roller for camshaft drive: Replace
(4-cyl. TDI pump jet engines)
Every 120,000 km
Toothed belt: Replace (6-cyl. 5V, 2.4 litre; 3.0l engines)
Toothed belt for camshaft and injection pump: Replace (V6 TDI engines)
Every 180,000 km
Toothed belt: Replace (4-cyl. 5V, 1.8 litre turbo engines)
Toothed belt: Replace (4-cyl. 5V, 2.0 litre engines)
Toothed belt: Replace (4-cyl. 4V, 2.0 litre engines)
Every 24 months
Brake fluid: Change
After the first 36 months, then every 24 months
Exhaust emissions test
Every 48 months
Telematics: Replace emergency backup battery
Work to be completed
Electrical System
Check operation of front lights: Side lights, dipped beam, main beam, front fog lights, turn signals, hazard warning lights
Check operation of rear lights: Brake lights (incl. high-level brake light), rear lights, reversing lights, rear fog light, number plate light, turn signals, hazard warning lights, luggage compartment light (several lights)
Interior lights and glove compartment light, warning lamps, horn: Check function
Convertible top: Check function
Note: With convertible top open, rollover protection: Check function (every 2 years)
Self-diagnosis: Interrogate fault memory with fault reader V.A.G 1551 or VAS 5051
Service display: Reset; LongLife
Telematics: Renew the emergency backup battery (every 48 months)
Vehicle, from outside
Tailgate/boot lid hinges: Lubricate. up to chassis no. > 080 000 model year 02
Door arrester, lock cylinder and bonnet release catch: Lubricate
Sun roof: Check function, clean guide rails and spray with lubricating spray
Windscreen wiper and washer system and headlight washer system: Check washer jet settings
Wiper blade park position: Check
Wiper blades: Check for damage
Tyres
Tyres, spare wheel: Check condition and wear pattern; record tread depths
Tyres, FL: Check condition and wear pattern; record tread depths
Tyres, RL: Check condition and wear pattern; record tread depths
Tyres, RR: Check condition and wear pattern; record tread depths
Tyres, FR: Check condition and wear pattern; record tread depths
Tyre repair set: Check expiry date
Vehicle, from below
Engine, gearbox, final drive, steering and protective boots: Visual check for leaks and damage
Multitronic gearbox: Renew ATF
Engine oil: Drain or extract, change oil filter
Manual gearbox/final drive: Check oil level and top up if necessary
Final drive (automatic gearbox): Check oil level and top up if necessary
Brake system (from below): Visual check for leaks and damage
Brake pads: Check thickness
Underseal: Visual check for damage
Exhaust system: Visual check for leaks and damage, check that parts are properly secured
Track rod ends: Check play, attachment and protective boots
Ball joints: Check protective boots for leaks and damage
Engine compartment
Engine (from above) and engine compartment: Visual check for leaks and damage
Engine oil: Fill
Battery with magic eye: Check display and top up with distilled water, if necessary
Windscreen/headlight washer system: Top up fluid
Cooling system: Check antifreeze and coolant level/antifreeze specified value -25 �C;
Actual value (measured value):
Hydraulic system: Check for leaks, check fluid level and top up hydraulic fluid if necessary
Air cleaner: Clean housing and replace filter element
Spark plugs: Replace
Fuel filter: Replace
Dust and pollen filter: Replace
Toothed belt for camshaft drive: Check for damage and check tension
Toothed belt for injection pump: Check for damage and tension, adjust toothed belt tension - additional work
Toothed belt: Replace - additional work
Toothed belt and tensioning roller for camshaft drive: Replace (1.9 litre TDI pump jet) - additional work
Toothed belt and tensioning roller for camshaft drive and toothed belt for injection pump: Replace - additional work
Poly V-belt for alternator: Replace - additional work
Change brake fluid (every 2 years) - additional work
Note: Never remove strainer from brake fluid reservoir
Concluding work
Tyre pressures on all 4 wheels and spare wheel: Check
Store modified tyre pressure values in driver information system (DIS)
See Owner's Manual "(DIS) store tyre pressures"
Headlights: Check settings and adjust if necessary (ellipsoid headlights)
Headlights: Check settings and adjust, if necessary (gas discharge headlights)
Test drive: Perform
Old 30th July 2014, 04:43 AM
Sure, but having said all that. The D4 has two services one is an oil change and one is real service.
They are both are shown in the MMI page with a millage countdown and day countdown.
So the oil service on my D4 3.0 TDI is exactly that. Change the oil, change the filter and a new washer on the sump plug ... nothing else...
My next service is now due in 2,200 miles. My next Oil service is due in 15,000
I appreciate the downer a lot of people have on Kwickfit, but in reality they are not that bad for what they know.
Is there anyone on this site who wouldn't buy tyres off them? (for the right price)
I won't be putting the car in at Kwickfit for its service, I'm eying up a local Audi specialist independent garage.
BTW: my back brake pads are still going at 9K miles.
Old 16th July 2014, 01:33 AM
sarg sarg is offline
I doubt it, the additional depreciation lost because of a KwikFit 'service' history will cost you more in the long run, plus untold problems caused by lower quality components and fluids probably fitted by a spotty teenager just out of school.
If you want to save money, go for it, but not KwikFit and their like, at least find a decent indy, I wouldn't let them anywhere near any of my cars, not ever.
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 16th July 2014, 07:37 AM
Two true Kwik Fit stories:
1. Some time ago I took my D2 to a local indy for a few jobs, including a wheel alignment check.
When I picked it up, the 'alignment' had resulted in a car that didn't feel right and a steering wheel that was miles off 'straight'.
When challenged, the indy confessed that their alignment machine was faulty, so they'd sent the car to the local Kwik Fit! The indy sorted it properly on their, now working, machine and gave me a refund.
2. Many, many moons ago, I drove a Triumph Spitfire and got a puncture. So I swapped it for the spare and took the punctured wheel into Kwik Fit for repair. Picked it up a day later and went to put it back on the car as the 'spare' was a little lacking in tread.
It didn't fit! Clearly, they'd mixed my wheel up with one from another car. They assured me they knew which car had got my wheel and they'd get it swapped. But after 2 months of fobbing me off with one excuse after another, I insisted that they bought me a new wheel and tyre - which they eventually did.
But I always wondered about the poor sod who had my Spitfire wheel as a spare in his boot. He probably got a puncture one dark, wet night, went to put the spare on and it didn't fit!
The moral of this story is "You can't get better than a Kwik Fit f**k-up".
Old 16th July 2014, 09:14 AM
Duffy Duffy is offline
My summer toy is a Porsche Boxster 987 3.2S, the perceived wisdom to stop the engines going 'bang' is to double up on oil changes. It's relatively common practice for us to use Kwik Fit for this as they usually use Mobil 1 fully synthetic and an OEM filter, all for 25-33% of the price of an OPC.
Kwik Fit use an oil change as a loss leader to get you in the door in the hope of getting other, more profitable,work whilst you are there).
I wouldn't use them for a proper service, however, for an oil change, it's a no brainer.
I hang around whilst they do it though.
1988 Audi 90 2.2E
2011 Mercedes E250
2016 Abarth 595 Competizione
2012 Porsche 981 3.4S PDK mid life crisis!
