D2 - Everything else Anything that doesnt fit elsewhere |
Update:
Car has been at Motor Continental since Thursday - they were actually more expensive than Audi for the Cambelt and water pump service, however I wanted to get a few other things looked at and I'm guessing this would have worked out expensive at Audi. A fair bit of work undertaken, together with a couple of unplanned items: Cambelt inc tensioners, pulleys and damper Auxiliary belt inc tensioner Thermostat Water pump Gear box oil/filter change Spark plugs Assuming Engine Oil and filter as oil cooler has been dropped The unplanned work relates to a coolant leak from the plastic pipe to the oil cooler - this has cost me another 3hrs of labour, the part itself is a tenner or so. And today, I get a call advising me the alternator is kaput, potentially as a result of the coolant leak directly above it. This just as they'd buttoned everything up and were running the engine temps up when a plume of smoke from the alternator stopped play. There aren't too many choices online for replacements in stock, so will probably go with a genuine replacement, unless someone can recommend an alternative ? Might be a bit snobbish however I don't want a Lucas item in this car! Not been a cheap month if I include the purchase itself - planning to get new tyres and wheels refurbed the following month, together with a 4 wheel alignment assuming all suspension parts check out via visual inspection. I can't wait to get it back - 991 oil cap also ordered, as well as a spare Airbox lid from the hosts so I can get drill happy and get some induction noise going ![]() |
I would leave your snobbery at home tbh otherwise your bill is going to get even larger
Erm .... kinda too late!
Its very feasible this bill will top £1500 which is a ridiculous outlay on a 3k-ish car - somehow, my man-maths suggests this is perfectly reasonable .... |
So a pretty hefty bill came my way 2 weeks ago and was actually higher than the purchase price of the car!
All labour based on a rate of £52.50/hr This wasn't helped by a failed alternator and the rubber pipe to the oil cooler needing replacement. Plus I replaced both of the pre cat lambda sensors, and both of which were pretty much welded in. I seem to do this with all the cars I buy, it makes me feel better even though it's makes little sense to anyone else ![]() Benefits?: Gear change has improved subtlety idle which is now much more solid. Engine light extinguished (spendy!) Peace of mind (!) Tyres, wheels and alignment next. Front discs/pads are 70% worn, rears are 30% Procured an air box lid for some cheeky sound improvements To the bill... Just the total on the 3rd page - hopefully this is of use to someone ![]() ![]()
Shirish: 2001 S8 |
I thought the oil should be 5W-30?
5w30 or 5w40 are the usual choices. You can go as low as 0w30 but that's a bit thin on cold start for my likeing.
10w40 shouldn't be an issue, it's just thicker on cold start
I took their recommendation on the oil, which was partially based on only expecting I'd cover 2-3k miles this year. I'd prefer to use a 5w/40 but would rather dispose of 10w/40 rather than 5w/40 after 3k miles use.
Having said that, either quantum platinum or total quartz 2000 is available for £21-22/5litre so may try that next time
Shirish: 2001 S8 |
Hmm, engine light is back on again today having been extinguished since picking the car up 2 Friday's ago.
Starting from cold, there was a strong smell of it running rich from the exhaust - hope it's something other than the 2 pre-cat lambda sensors which were replaced as part of the service at great expense thanks to the down pipes being dropped.
Shirish: 2001 S8 |
