Old 9th April 2015, 10:11 AM
tipptop tipptop is offline
Nope just the rear pads worn code, implausible signal. Only two other codes across the entire car are an engine mount and a handle touch sensor...
Possibly the calibration won't perform while the 02596 is latched, it comes back immediately when I clear it though so I don't know what to try next.
A8 D3 3.0tdi quattro 2006
A6 C5 1.9tdi 2004
A4 B5 1.9tdi quattro 1997
Old 9th April 2015, 12:38 PM
Disconnect battery for 30min?
Old 9th April 2015, 01:39 PM
I agree it might clear any resident memory in the EPB module if you do that
Old 9th April 2015, 04:19 PM
Thanks for the replies. Ok tried disconnecting the battery, left it off for 40 mins, charged it while it was off. Reconnected it and ran the adaptation and function test again several times, still can't clear the code and calibration won't run after I lock the car with the ebp left off..
This is the code.
1 Fault Found:
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 48
Time Indication: 0
Date: 2064.00.00
Time: 00:00:00
Freeze Frame:
Voltage: 9.63 V
Count: 61
A6 C5 1.9tdi 2004
Old 9th April 2015, 04:29 PM
Have a look at the ross tech wiki page HERE
particularly -
When 02596 - Rear Brake Pads Worn is stored after the pad thickness is adapted, try:
Repeating the Function Test Basic Settings operation and make sure the stored value in Adaptation channel 006 did not resort back to 03. If that alone does not resolve the issue proceed to 2:
Test drive the vehicle and scan it to see if 02596 - Rear Brake Pads Worn switched to Intermittent, allowing you to clear it.
Old 9th April 2015, 04:39 PM
This also maybe of interest...
http://www.audiworld.com/forums/a8-s...t-new-2881667/
Matt
Old 9th April 2015, 04:41 PM
Thanks for that, not sure how I missed that bit! I presume they mean to scan the car while driving and check to see if it changes the intermittant? The adaptation of 11mm stays put, it doesn't revert to 3mm.
A6 C5 1.9tdi 2004
Old 9th April 2015, 04:47 PM
Thanks, I was thinking of separating the plugs and cleaning the contacts, seems a lot of issues with them, although surely another code would be stored along with with 02596. When he says hall sensor connector I presume its the plugs of the motors out at the caliper?
Ok so I tried scanning while driving, no change but also you lose communication with the epb controller when you start moving. I think my last resort at this will be to clean the motor connectors.
A6 C5 1.9tdi 2004
Old 9th April 2015, 09:15 PM
Somerandomguy's Avatar
I had a bit of a faff getting mine to clear error codes, and althougn I cant remeber the exact details, I seem to remeber having to switch on basic settings at some point. Could it be this?
Old 9th April 2015, 10:47 PM
Hi, i'm not quite sure what you mean by 'switch on basic settings'. I go into basic settings to run the function test after the pad thickness adaptation, maybe this is what you mean...
My understanding of the process is:
Connect charger.
Cycle epb on and off again.
Open epb fully in basic settings, group 007, wait 30 seconds then close controller.
Change pads, pump brakes when done to get everything snug
Close ebp fully in basic settings, group 006, wait 30 seconds then close controller.
Put in new pad thickness in adaptation, group 006.
Run function test in basic settings, group 010, ebp moves in and out 3 times, wait 30 seconds then close controller.
Ross tech says you may need to run the adaptation and function test a few times until you can clear the pads worn code. I've done it maybe 15 times now!
Other people are saying you need to then turn off ignition, lock steering, epb left off. Lock car and epb should move and calibrate itself. This last bit definitely doesn't happen on my car.
A6 C5 1.9tdi 2004
