Old 21st August 2015, 03:55 PM
mannyo mannyo is offline
After a number of drive cycles today, following the 1/4 turn clockwise on the vertical adjustment I now have the below. I know which is horizontal now, just need to work out which way to try tweaking that. Still does not pickup cars, so maybe its also pointing off left/right.
Manny
Past
Old 21st August 2015, 05:12 PM
Progress in the right direction, I like it, if you don't mind me asking which block do you think does what?
Old 21st August 2015, 05:34 PM
i am not sure yet, as altering the vertical seems to have altered both readings. its still not picking up cars in front.
Tomorrow I am driving up to Boston in Lincolnshire, so when on the A1 I'll try moving left to right whilst following another car and see if it picks anything up then try to correct that.
Manny
Past
Old 21st August 2015, 07:01 PM
Hopefully I can persuade it to pickup a lock on a lorry or something on the drive up tomorrow, I'll scan again and see what readings I have then. If the other reading pops up about the same as before, then I'll tweak the vertical adjustment another 1/3rd clockwise and redo the basic settings.
Manny
Past
Old 22nd August 2015, 11:38 AM
First of all Great write up ! And I have a question.. what are the actually operating parameters?
Is it all ment to be zero ? ...
I have the same problem on mine .. but it only started doing this since a stone hit the acc cover and broke it.. it's been replaced with a non W12 acc cover because Audi say it's part of the grill ... dose any one have the part number for the W12 ACC cover plate ...
And manny if you know what the parameters are let me know and il check mine ... I'm stuck in bed with vertigo at the moment
Old 22nd August 2015, 01:20 PM
They are meant to be less than 0.5 degress so mine is just inside
I'm going to try and get it closer at some point because I can feel a bias to one side that is noticeable on sweeping bends.
And your ACC cover is 4E0 854 511 AA
Old 22nd August 2015, 03:10 PM
Posting this from Boston, Lincs.
I managed to pickup and follow a lorry with ACC switched on, on the A16 so just done a quick check of the angles.
I currently have the below showing.
From adjusting the vertical screw 1/4 turn the value in measuring block 2 reduced significantly whereas the value in block 11 has returned to about where it was before.
I just need to work out if I need to turn the horizontal adjustment clock or anticlock to get closer to zero.
Manny
Past
Old 22nd August 2015, 05:14 PM
Mmmm interesting, you went from this.
To this after a basic setting
To this
So I will wait with anticipation to see what you get on your return journey after you tweak the horizontal screw.
I got quite a jump in my figures from the last set of readings but its still working????
Old 22nd August 2015, 08:19 PM
i managed to have a play in the centre lane of the A1 peterborough bypass on the way back. The ACC seems to pickup cars if I move towards the hard shoulder, so tomorrow before heading back to Dorset I am going to try a half turn anticlockwise on the horizontal adjuster.
Manny
Past
Old 22nd August 2015, 09:17 PM
I think its pointing to the right because if I move over to the left and straighten the wheel it seems to pickup the car in front.
Manny
Past
