Old 15th January 2016, 12:44 PM
Options are listed in the build sticker.
See IT's post here
http://forum.a8parts.co.uk/showthread.php?p=57
Also, registering your car with Audi.co.uk will also give the options.
Edit,
Or do you need an option decode?
http://vag-codes.info/
Matt
Old 15th July 2016, 01:08 PM
Turbo Tony's Avatar
Hi all,
Yes, I'm at it again... resurrecting old threads!
Coming in to work today and I noticed the rear screen was misted over. I turned on the heated screen and it had no effect. It stayed on for around 10mins but still, no visible effect on the screen.
Now, it was quite warm this morning (maybe 11 degrees?). Do you think the electronics have told the system the heating isn't needed?
Or am I about to lose another few thousand replacing the rear screen?
Mine is heat reflective, so has the really fine elements that are almost invisible.
Storytellers Villa Orlando
2008 Audi S8
Old 15th July 2016, 01:39 PM
Turbo Tony's Avatar
I should have added - VCDS showed nothing in the scan.
2008 Audi S8
