Old 16th January 2016, 06:17 PM
Conquistador's Avatar
Default Lowering D3 using VCDS coding
Was curious to see how the S8 would look a little lower so I connected it up to my laptop...34-Level control...Coding then changed the 'xxx55xx' to 'xxx11xx' pressed 'Do it' and nothing has really happened.
I went for a short drive and turned the car off and on a couple of times expecting the car to lower at some point but nothing...
Am I missing something or have I done something incorrectly?
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 16th January 2016, 06:31 PM
Lee S Lee S is offline
Once you've changed the coding you need to do the adaptation on each corner which involves measuring the existing height and inputting slightly altered versions. There are plenty of guides on the web.
Lee
2017 Nissan Leaf Tekna
Old 23rd January 2016, 05:35 PM
Of course, thanks.
I tried adaptation just now, put all the correct measurements in then went to channel 05 and got a red error...
However, the car does have a suspension malfunction according to VCDS as follows:
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 L HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 6340
Coding: 0011110
Shop #: WSC 02313 785 00200
VCID: 2C5172EB8F89E57E17F-8079
1 Fault Found:
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 60
Mileage: 166737 km
Time Indication: 0
Date: 2016.01.13
Time: 22:25:28
Would this throw a spanner in the works??
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 23rd January 2016, 06:56 PM
I believe that the code you have there can be the compressor taking to long to get to desired pressure , had the same code on an Audi all road few years back , a new piston ring kit on the air compressor got rid of the code .
Old 23rd January 2016, 07:58 PM
Sounds like you may need the bagpiping andy kit from eBay. I've just replaced the seals in mine but didn't have issues, did it more proactively before any issues cropped up as they seem to start causing issues at 100k miles plus
By the way bagpiping andy can also offer brand new cylinders now as well if the current one is damaged
Link for the video on fitting the kit -
http://www.bagpipingandy.com/installation.html
Old 24th January 2016, 09:50 AM
SilverS8 SilverS8 is offline
If you plan is to have lower on permanent basis, I would go for the Lowering kit
http://airridelowering.com/?tcp_prod...8-s8-2002-2009
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
