Old 12th July 2016, 06:05 AM
Strength no issue, there is a huge safety factor in them i'm sure. Just look at it. Or lay it down next to the jack. I reckon you could pick the whole car off the ground with the tow bar
Old 12th July 2016, 08:33 AM
However, Dezzy, the manual (who reads that!) states in bold that the maximum vertical force should not exceed 95kg. So i guess the towbar fixings are designed to accept 2300kg (+safety margin) in a fore and aft direction but only around 5% of that in the vertical. Therefore two average adults would exceed the designed max load though there wont be too much dynamic loading unless..... i dont want to even imagine that
Old 12th July 2016, 08:38 AM
95kg is the static nose weight, when your doing 70mph and bounce over a pothole with a trailer hitched I'd imagine that would increase significantly momentarily.
So long as you don't use your hammock at speed I don't think you will do any harm
Old 12th July 2016, 08:40 AM
I was meaning the location of the weld may compromise strength and the "safety factor"
Old 12th July 2016, 12:41 PM
Yeah agree David totally i looked when i was dragging the trailer around. But i thought that was more of a towing thing to get the trailer or towed sat with the car to reduce the risk of swaying or what ever its called.
not to the point you'd have to worry about it with a couple hundred kilos. We're talking small weights really. An inch of "good" weld will hold a ton.
Obviously as soon as you do weld it you'd loose all manufactures type approval.
I'd be happy sat on that put it that way, although one thing i would do is radius those corners with 10mm rad min. If you were to shin one of those it would hurt...... for hours
Old 3rd April 2017, 03:08 AM
CaifanSC CaifanSC is offline
did anyone try this????
Audi V8 Quattro Original 5speed - Black/Black
Audi S8 - Avus/Oxblood
Audi S8 - Cashmere/Twist
BMW 850i - Red 6speed
BMW 850Csi - Red 6speed
Ford Thunderbird x 3 Supercharged & 5speeds
Mustang convertible
Range Rover Autobiography - BRG/English Tan
