D3 - Everything Else Anything that doesnt fit elsewhere |
Thread Tools
Display Modes
Hi all,
It's been a while since i've posted but i've kept an eye out on the forum and been enjoying the 8 in the meantime. For about 2-3 months now, I've been suffering from a parasatic battery drain which means that if the car is left for 2 weeks without driving, it struggles to start. If left a week, i also notice it's down but a bit better. Below is the last scan I did at the end of October which i was hoping might give a clue. I can't remember if i cleared the fault codes afterwards or not but i can do another scan later this week to check. I haven't changed the battery and am reluctant to do so without eliminating the other potential causes first and wanted to check what methodology others go through to find out where a drain might be coming from. For reference, the following are known to me: - TPMS has been disabled - Soft close driver handle stopped working a few years back - Rain sensor replaced in March - i can clear codes to see if it re-appears - Auxiliary parking heating has never worked - Driver identification component protection has always had this Your advice is greatly appreciated. Oli OBDeleven data log Date: 2016-10-30 10:47 VIN: WAUZZZ4E26N019357 Car: Audi A8 Year: 2006 Mileage: 206060 KM --------------------------------------------------------------- 02 Transmission Control Module System description: AG6 09E 4,2lTDI RdW Software version: 0030 Hardware number: 4E1910156P Serial number: 0076831 Coding: 0000001 Trouble codes: No trouble codes found --------------------------------------------------------------- 05 Kessy System description: FBS AUDID3 H10 Software version: 0190 Hardware number: 4E0910131 Serial number: AUX3Z0F0383869 Coding: 0412672 Subsystems: System description: ELV Software number: XXXXXXXXXXX Software version: XXXX Trouble codes: 00179 - Driver access/start authorization antenna Upper limit exceeded static 00668 - Vehicle voltage terminal 30 Lower limit not reached Intermittent --------------------------------------------------------------- 06 Seat Adjustment Passenger Side System description: Sitzmemory BFS H02 Software version: 0010 Hardware number: 4E0910760D Serial number: 5DS 008 795-03 Coding: 4063328 Trouble codes: 01725 - Longitud. adjustment switch, backward, driver seat mechanical malfunction Intermittent 01724 - Longit. adjust. switch, forward, frt. pass. seat mechanical malfunction Intermittent 01970 - Depth adjustment button, backward mechanical malfunction Intermittent 01969 - Depth adjustment button, forward mechanical malfunction Intermittent --------------------------------------------------------------- 07 Display Control Unit System description: Interfacebox H43 Software version: 5570 Hardware number: 4E0910769Q Serial number: 300AC067562505 Coding: 0000002 Subsystems: System description: Bedienteil MMI H42 Software number: 4E0910609A Software version: 0020 Trouble codes: No trouble codes found --------------------------------------------------------------- 08 Air Conditioning System description: KLIMAAUTOMAT 016 Software version: 0400 Hardware number: 4E0910043B Serial number: 00000000088042 Coding: 0022563 Trouble codes: No trouble codes found --------------------------------------------------------------- 09 Central Electrics System description: ILM Fahrer H14 Software version: 0230 Hardware number: 4E0910279Q Coding: 0133122 Subsystems: System description: Wischer WWS D3 H50 Software number: 4E2910113B Software version: 0420 Coding: 0000036 System description: REGENLICHTSENSORH11 Software number: 4E0910557 Software version: 0050 Coding: 0139548 Trouble codes: 01520 - Rain/light recognition sensor Lower limit not reached Intermittent --------------------------------------------------------------- 0E Media Player Position 1 System description: CD-Changer H44 Software version: 0470 Hardware number: 4E0910111F Serial number: AUZ5ZBF8049216 Trouble codes: No trouble codes found --------------------------------------------------------------- 11 Engine Control Module 2 System description: 4.2L V8TDI A000AGSª Software version: 0070 Hardware number: 4E1910409A Serial number: AUX3Z0F0383869 Coding: 0011773 Trouble codes: P1849 - Read DTC memory of transmission CM Implausible signal Intermittent --------------------------------------------------------------- 13 Adaptive Cruise Control System description: ABSTANDSREGELUNGH03 Software version: 0020 Hardware number: 4E0910561F Coding: 0011154 Trouble codes: 01316 - Brake control module Please read DTC Intermittent --------------------------------------------------------------- 15 Airbag System description: Airbag 9.41 H12 Software version: 3610 Hardware number: 4E0910655D Serial number: 0037P000DLH0 Coding: 0431707 Trouble codes: No trouble codes found --------------------------------------------------------------- 16 Steering Column Electronics System description: Lenksäulenmodul H13 Software version: 0040 Hardware number: 4E0910549 Coding: 0112151 Subsystems: System description: Lenkradmodul H07 Software number: XXXXXXXXXXX Software version: 0080 Trouble codes: No trouble codes found --------------------------------------------------------------- 17 Dash Board System description: KOMBIINSTR. VDO H70 Software version: 0410 Hardware number: 4E0910980N Serial number: AUDID3F0000091 Coding: 0000403 Trouble codes: 16346 - Control module Faulty static --------------------------------------------------------------- 18 Auxiliary Parking Heater System description: Heizgeraet H07 Software version: 0110 Hardware number: 4E0910105A Serial number: 00000009006406 Coding: 0000001 Trouble codes: 01412 - Glow plug with flame monitoring Implausible signal static 02251 - Heater unit locked static --------------------------------------------------------------- 19 Gateway System description: Gateway H11 Software version: 0090 Hardware number: 4E0910468B Serial number: 19004061088029 Long coding: FEFFFBDF2B7504 Trouble codes: 01325 - Tire Pressure Monitoring Control Module No signal/communication static 01044 - Control module incorrectly coded static 00467 - TV tuner No signal/communication Intermittent --------------------------------------------------------------- 1D Driver Identification System description: FPI_1 H06 Software version: 0060 Hardware number: 4E0910218 Serial number: 11082004063652 Trouble codes: 02095 - Component protection active static 00446 - Function limitation due to insufficient voltage Lower limit not reached Intermittent --------------------------------------------------------------- 1E Media Player Position 2 System description: SG ext.Player Software number: 4E0035785F Software version: 0850 Hardware number: 4E0035785C Hardware version: H20 Long coding: 010000 Trouble codes: No trouble codes found --------------------------------------------------------------- 25 Immobilizer System description: FBS AUDID3 H10 Software version: 0190 Hardware number: 4E0910131 Serial number: AUX3Z0F0383869 Coding: 0412672 Subsystems: System description: ELV Software number: XXXXXXXXXXX Software version: XXXX Trouble codes: 00179 - Driver access/start authorization antenna Upper limit exceeded static 00668 - Vehicle voltage terminal 30 Lower limit not reached Intermittent --------------------------------------------------------------- 34 Ride Control System System description: LUFTFDR.-CDC H06 Software version: 6310 Hardware number: 4E0910553J Coding: 0015510 Trouble codes: 01400 - Level control system Upper limit exceeded Intermittent 01398 - Signal wiring from central locking - doors open No signal/communication Intermittent 01772 - Sig. wire from level ctrl pressure sensor Implausible signal static 01577 - Switch-off due to excessive temperature Upper limit exceeded Intermittent --------------------------------------------------------------- 36 Seat Adjustment Driver Side System description: Sitzmemory FS H02 Software version: 0010 Hardware number: 4E0910760D Serial number: 5DS 008 795-03 Coding: 4063342 Trouble codes: No trouble codes found --------------------------------------------------------------- 37 Navigation System description: MNS ECE H47 Software version: 1060 Hardware number: 4E0910888P Serial number: 364AS067525548 Trouble codes: 02261 - Data medium Faulty Intermittent 02927 - DVD read error Intermittent
![]() CURRENT: 2006 Audi A8 D3 4.2 Tdi QS - CLICK HERE FOR PROJECT THREAD: Audi Exclusive Azure Blue, Amaretto brown interior, facelift rear lights, S8 mirrors, B&O, ACC, Digital TV, glass sunroof, Fridge, Extended Leather Pack 2, wooden steering wheel & gearknob, keyless entry, keyless start, electric boot, softclose doors SOLD : 2000 FL Silver D2 4.2 QS - Solar sunroof, Bose, Blinds, NavPlus, Playstation, DVD, wireless headphones, iPhone AV connection, RS6 steering wheel, chrome mirrors, phone prep, xenons, servotronic steering, Rear screen, TV-in-motion, NavPlus Alu rings, S8 exhaust, S8 bonnet grille, 385mm D3 S8 brakes, rubber winter mats, De-badged rear, US rear indicator clusters, 20" Final Edition diamond cut wheels, 15mm Eibach Pro spacers (front), 20mm H&R hubcentric spacers (rear). Audi A8/S8 D2 Flickr Group Last edited by Oli18; 28th November 2016 at 06:43 AM. |
