Old 29th May 2017, 08:33 PM
Excellent. I never had any problems getting them back in, it was always removal that was tricky.
Those screw holes need the screws refitting to hold the door trim securely where you pull on the grip to close the door.
Are yours missing, or did you just not spot the sequence of layers they went through before you took them out?
Old 29th May 2017, 08:51 PM
Spanker's Avatar
Spanker Spanker is offline
No, mine weren't missing. It's just that I took the photo BEFORE screwing them in.
And I thought I had the sequence memorised but just failed to spot that tiny detail of lugs in front instead of behind.
You live and learn
Dean
Old 31st May 2017, 09:16 PM
D2 FL cars came with two types of internal door handle inserts:
1. fake wood 2. plastic.
I have fake wood ones, but wanted to shift to plastic.
Do I understand correctly that plastic handle inserts from late FL D2 cars are made of two parts?
Here is an example of 2 part set: http://www.ebay.co.uk/itm/132008422603
However this set comes from 1998 car.
Are the facelift ones different?
Hi Sergey
I am confused about this thread, but I do have a set of genuine late FL (FE) plastic door inserts available. I replaced mine with 'dark maple' fake wood inserts and was planning to refurbish the plastic ones. But those plans are now abandoned as I like the 'wood' insets better.
Let me know if you're intersted.
Best regards, Jim
Old 31st May 2017, 09:21 PM
Jim, I expect yours will be like mine (but a different colour - black?) so will have the top surface actually painted metal. Have a careful look at them.
Sergey is trying to find parts that are 100% plastic to make painting/repainting easier. Though I would have thought that, with the right paints, it wouldn't matter.
Old 31st May 2017, 09:29 PM
Hi Jim.
As Andrew explained, I decided to use pre-facelift handles that are fully plastic and can be taken down to basic components. In the middle of previous page I showed 4 pictures of what I mean.
I ordered some parts from A8 Parts and from Audi Tradition to do this project and if I succeed I will do a write up.
Thanks for offering the handles. If my project will fail I will take yours.
P.S. I thought your car is dark Myrtle wood actually?...
Old 31st May 2017, 09:39 PM
A lot of the later cars (and maybe earlier ones too?) had just plain painted panels around the door switches, the same colour as the surrounding plastics.
Mine did originally but I swapped them for wood effect.
Old 31st May 2017, 11:01 PM
What colour?
Old 1st June 2017, 09:48 AM
What colour?
Platinum/ silver grey
