IT, AV and other Tech All computing, home cinema and technology that isnt car related |
Thread Tools
Display Modes
![]() Quote:
Certainly some cards are far more efficient at mining than others. If you're building a rig specifically for mining or it's a PC that wouldn't normally be on 24/7 you do need to take the rig 'overheads' (CPU, drives, etc) into account when calculating the running costs. If you can't make use of the heat generated or you want to get electricity usage down to a minimum, building a larger multi-card rig might make more sense. The rig overheads will be greater when mining with just a few cards. Also, depending on which card you use, you can usually make some adjustments to improve efficiency. For example, with the AMD cards you use the supplied AMD utility 'Wattman' to reduce the GPU frequency by about 15-20%. This has no significant impact on mining performance yet reduces power consumption from about 160W to 100W per card. For comparison, I have a 2 card AMD rig (RX 480) that consumes about the same as yours (~£27 per month) but makes about £100-£150 per month. Kaspersky is probably just triggering when NiceHash switches algorithms or makes new network connections. While it's best to experiment initially on an existing system, you'll have better results running the cards on a dedicated system without such aggressive antivirus/firewall software.
Mark ------------------------------------------------------ 2002 FE S8 Ebony Black Pearl ------------------------------------------------------ ------------------------------------------------------ Cars Owned: The Tesla Era: 2020 Model S Performance Ludicrous+ (present) (Black, with all black premium interior and carbon fibre décor, 21" sonic carbon twin turbine wheels and FSD capability) The Audi Era: '97 A8 4.2 (Ming Blue) --> '96 A8 4.2 QS (Dark Green) --> '02 FE S8 (present) The Citroen Era: '84 BX 1.6 RS --> '89 BX 1.9 DTR Turbo --> '94 XM 2.0L Turbo --> '96 XM 2.0L Turbo Exclusive --> '00 Xantia Activa 2.0L Turbo The Banger Era: '76 1.2L Lada VAZ-2101 (Ruski Fiat 124) --> '80 1.7L Morris Ital HL, finished in Ermine White and Rust Last edited by moltuae; 26th June 2017 at 09:24 PM. |
I've moved this thread to "IT AV and other Tech" as it sits better here
![]() Quote:
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 26th June 2017 at 10:01 PM. |
![]() Quote:
Just setting up one of the laptops now. Core i7 with a GTX280 so we'll see what that can do to get going and then have a play with the 960 ![]() |
Well that was a waste of time. Nethash Miner won't detect CPU or GPU on my i7 laptop
Laptops are generally no good for mining. Even if they have supported hardware, they're not designed to be run at full power for extended periods. Cooling is very limited and frequently running BGA (ball grid array) type CPUs/GPUs hot can lead to faults caused by solder fatigue.
It's best to stick to using full size systems and one of the graphics cards listed here: https://new.nicehash.com/profitability-calculator
![]() Quote:
Following this thread with interest. ![]() Is it possible to build a rig into a proper pc case or is it usually Frankenstein'd? I have a silverstone TJ-07 case thats never been used sitting in the loft. Also surprised to see they don't use liquid cooling for quietness and maybe heat recovery to be used for the house?
Del ![]() Last edited by Delboy; 27th June 2017 at 09:01 AM. |
Certainly, though you'll be limited by the number of cards you can physically fit in there of course. You'll be lucky to find a case that'll take more than a couple of full size graphics cards, though you may be able to squeeze an extra one into a couple of 5.25" bays if you can find a way to mount it. Also depending on the PSU the PC originally came with, you may need to upgrade that to cope with the extra wattage.
![]() Quote:
The fans in the GPU rigs aren't particularly loud and you can use the heat to heat your house/office. I used my Antminer S9 (which is loud!) to heat my workshop for the latter part of last winter. I usually use an electric heater but with the Antminer pumping out 1.3kW of heat continuously I didn't need any extra heating. So it didn't save be anything on my heating bills but it effectively cost me nothing to run either. Over a 3 month period it probably made me about £1000. I've since moved it to my customer's server room (where it has all the free electricity it can eat). This is the customer I'm helping to build a mining farm for, so I get to use their electricity for free as part of the deal ![]()
#30
Anyone looked into dumping a PV install on their garage roof and running one off that or would the power setup not work/be reliable enough? Just thinking aloud here... what sort of bandwidth drain does this have on your internet connection as well?
