Old 24th July 2017, 09:00 AM
MikkiJayne, Well done and having the idea to use time lapse photography is brilliant.
Old 24th July 2017, 08:35 PM
Kewl with a capital K!
Old 26th July 2017, 09:04 AM
Brilliant!
Huge respect, this cradle must make things a lot easier, although I would never attempt removing the engine and the trans myself.
I have enough trouble doing simple things like changing the temp sensor and checking the gearbox oil.
Old 26th July 2017, 08:32 PM
Many jobs are so much easier with the engine out though I've done cam chain tensioners, the oil cooler pipe, every oil seal, sump re-seal (upper and lower) and all hoses on this one while it's out to have the torque converter swapped. Also the gearbox filter and sump re-seal are much easier with it upside down!
Cleaning the engine bay is much easier without an engine in there too
Interesting discoveries - all the water hoses are still available bar one of the two heater hoses, and for a total of only £150 or so! The rear crank seal however, despite having an 078 (V6) part number is not available. You have to swap the entire rear cover plate for £286! Lol no An SKF viton double-lip 105x85x12 oil seal is £30 thank you very much. Bizarrely, the front crank seal, specific to the V8 is £7
Old 27th July 2017, 09:15 AM
Great time lapse I did think about doing one! But that's as far as I got.
Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
Old 28th July 2017, 08:42 PM
I made another thing:
Start with a lump of billet aluminium
Drill a hole in the middle
Clean up the hole & start cutting out a recess
Make the recess a bit deeper
Remove everything which isn't part of the tool
Leaving this
Which fits over the subframe bushes like this and will push on the flange without damaging the mounting bobbin in the middle
A pair of these and some chunky threaded bar should pull the bushes in to the subframe nicely
Old 28th July 2017, 09:01 PM
You really take me back to my younger days. We used to make everything ourselves. I'm too old to bother the same now.
Really like the photo guides. !!!
Old 30th July 2017, 09:17 AM
Made another aluminium piece, and this is how they work:
Old 30th July 2017, 10:02 AM
All eight done
Old 30th July 2017, 12:50 PM
Awesome
Is that tool available for rent?
I'm having my rear subframe replaced in a few months time (if you recall I had the front subframe changed a while ago, for which you loaned me your alignment pins).
Your new tool might come in handy for the rear bushes.
How much did the new bushes cost?
